Drag strip trip.
- zukdave
Re: Drag strip trip.
08 Apr 2015 18:32 - 08 Apr 2015 18:33
78kzturbo Thank you for enjoying my story.
I've been using this thread to keep a record of building
my little bike, what I've put into it and the fun I've had with it.
Everything I've done to this bike since the first time at the track
is in here somewhere.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 08 Apr 2015 18:33 by zukdave.
- zukdave
08 Apr 2015 18:50
I did get some shit done on the bike after work today.
I stripped every wire out of the bike, pulled the stock
ign. pickup and rotor off, removed rear inner fender.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
10 Apr 2015 17:47 - 10 Apr 2015 17:53
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 10 Apr 2015 17:53 by zukdave.
- 78kzturbo
10 Apr 2015 19:34
what size cams are you running? are your valves oversized? what are you current quarter mile times?
- zukdave
11 Apr 2015 05:40
Right now it has the stock GPz cams and stock size valve's.
!/8 mile time's work out to about an 11.55.1/4 mile.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- 78kzturbo
11 Apr 2015 11:45
That's pretty good considering no slick air shifter stock cams and valves. I think your riding that bike pretty damn good. have you thought about what size cams to run? These kawasaki's really work good running staggard cams.
- DOHC
- Those Doe-Hawks really go!
12 Apr 2015 07:11
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Here is a DRL400:
zukdave wrote: The 2000 doesn't have the 2 step feature I'll still need the
Drl400 box.
Here is a DRL400:
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- zukdave
12 Apr 2015 18:46
Dave as for cam's I'm thinking 395/260@050 from webcam's.
I plan on spraying this motor so thinking a little milder cam and
not beat on the valve train that hard.
Did get to play with it today got the new inner fender ruff cut and mounted
stll need to clean up the cut's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- riturbo
14 Apr 2015 22:11
Looks good Dave nice work. Had fun the other night at the bike show . It was great to meet you.
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- zukdave
16 Apr 2015 18:27
Was cool meeting up at the show I saw you're post
on the turbo site glad you had a nice time here in Tx.
Got about 90% of the new wiring harness done last night.
Ign. switch wired, start button wired, charging system wired,
headlight wired,
Still need to do new starter to solenoid cable, a few ground's
connect the rear light's then finish setting up the new ign.
headlight wired,
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
18 Apr 2015 12:34
I got the harness done fired the bike and all the smoke stayed in so we're good.
Loaded the bike and all the shit to camp at the track tonight
and get some test pass's before tomorrow's all bike race so checked the web site
and they cancelled tonight's racing because of a chance of storm's later today.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- kawi810
18 Apr 2015 13:12
hey DAVE have fun camping .did you get the software to adjust the timeing curve?i am interested in the results. john
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
