Drag strip trip.
17 Feb 2015 20:29 - 17 Feb 2015 20:38 #661935 by zukdave
Replied by zukdave on topic Drag strip trip.
I flat love my little bike and bracket racing I CAN beat a busa.
I know it don't mean chit but I'm gonna build the quickest
KZ650 I can.
Best number's I've seen are Denco's modded KZ650
that's said to have gone 10.97.slick and a bar.
So 10.80's no bar street tire should trump's that
and I'm Real F'in quick. :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
I got some work to do :whistle: :whistle: :whistle:
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 17 Feb 2015 20:38 by zukdave.
19 Feb 2015 06:23 #662040 by DSummerlin
Replied by DSummerlin on topic Drag strip trip.
Hell, yeah, Dave. This has been a great read and really cool to learn where you've been with that sweet ass bike. We met at the show at revival cycles and I saw your bike there, but didn't realize how serious it is... You reached out about riding last year, but this year for sure. You thinking about going to Leaky in may? Drag Racing....... Might be some new bikes to shame.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
19 Feb 2015 15:36 #662084 by racer54
Replied by racer54 on topic Drag strip trip.
Many years ago there used to be a KZ650 at one of the local tracks. Ran slick and bars. It had to be modified for sure but no idea what he did to it. It ran in the 10.6-10.7 range all day every day. It was the only one I knew of that ran that fast. It was painted in the green Kawasaki color with stripes like the old GPZ scheme.
19 Feb 2015 15:53 #662088 by zukdave
Hey how's it going ? You got my number right give me
a call sometime.
As for Leaky I was thinking about it I'd just have to trailer out.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
19 Feb 2015 16:39 #662096 by zukdave
I did get the head on the motor last Sat. but when doing the
shims the smallest I had was 2.25 and still to tight so called
Curtis who did the head he said bring it to him and he'd tip the
valve's and get the shims in the 2.50 range no cost to me.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
22 Feb 2015 16:49 #662422 by zukdave
Got the head back last night and weather today sucked so I
stayed home, watched Nascar and did this.
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
26 Feb 2015 17:25 #662838 by zukdave
Ok enough of this cold/wet weather this weekend cold or not I'm
going to get head on and the motor back in the frame.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
08 Mar 2015 19:32 #663791 by zukdave
Motor's all done but the clutch and that should be here mid. week
so started making some alum. motor mount's and valve cover
block off plate's.
[IMG
Also broke down the carb's and ran them thru the sonic cleaner.
Based on jetting old motor I'm gonna go up to 20 pilot's and 122.5 main's.
because thats the largest i have.
Sudco's web site says 25 pilot's and 122.5's as a base line.
starting point.
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
08 Mar 2015 19:43 #663793 by Patton
Replied by Patton on topic Drag strip trip.
Carbs look exceptionally nice and clean! :cheer:
Any tips on product or formula used in the sonic cleaner, how long immersed in the sonic bath?
Did float bowl interiors come out just as well?
The result looks as good or better than soda blasting.
Good Fortune! :)
08 Mar 2015 20:49 #663800 by zukdave
Pattin I did these with a 20-80 mix simple green to water at
150 degrees for about 30 minutes and they look the same inside.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: Patton
10 Mar 2015 18:34 - 10 Mar 2015 18:41 #664022 by zukdave
Honey I'm home
[IMG
Some pic's of the new mount's still need to adjust spacers and bolts for
the thicker plates.
[IMG
[IMG
[IMG
[IMG
Not bad for a jig saw cut block off plate.
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 10 Mar 2015 18:41 by zukdave.
12 Mar 2015 17:46 #664257 by zukdave
Got some new sticker's today
[IMG
They were in the box with this.
[IMG
[IMG
[/URL
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
