Drag strip trip.
07 Jan 2015 18:53 #658011 by kawi810
Replied by kawi810 on topic Drag strip trip.
hey my 810 cc pistons do look different
Attachment 107.jpg not found
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
07 Jan 2015 18:53 - 07 Jan 2015 18:58 #658012 by kawi810
Attachment 106_2015-01-08.jpg not found
i got them in 2000.
Last edit: 07 Jan 2015 18:58 by kawi810.
07 Jan 2015 19:04 #658016 by zukdave
Replied by zukdave on topic Drag strip trip.
Also look's like turn around time's on the cam's will be
cutting it close on my time frame so may run the GPz cam's at first.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
07 Jan 2015 19:07 #658018 by kawi810
well at least you can break the motor in and make sure your jetting is spot on .i did not install my cams untill a few years later.they do make a difference.
08 Jan 2015 17:33 #658107 by zukdave
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
09 Jan 2015 10:20 #658177 by zukdave
Just order'd APE H/D cylinder stud's, H/D head nut's and
.440 lift valve springs.
Next pay day will order the titanium retainer's and lock's
and get the block bored then get this thing back together.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
09 Jan 2015 11:17 - 09 Jan 2015 11:25 #658182 by kawi810
it was recommened that i use the titanium retainers .i think i will by them also.i only want to put this together i more time.and i am putting in a oil pump and relief valve from a 2001 -2005 ZR750-H1 ZR-7S recommened on 750 turbo. part#16082-1158 for oil pump and 16130-1058 for relief valve.i more thing i have to replace my clutch dampeners.totaly shot i will bring to work and drill out the rivets. somebody on 750 turbo selling viton ones.
Last edit: 09 Jan 2015 11:25 by kawi810.
09 Jan 2015 11:50 #658185 by KZB2 650
Replied by KZB2 650 on topic Drag strip trip.
The 700cc pistons I got two years ago looked just like Zukdaves .... in a smaller size of course.
Lookin forward to seeing your time slips.... sounds like your really doing it up right and am thinking the thing is gonna fly.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
09 Jan 2015 12:14 #658186 by zukdave
Well judging by the cylinder's it was running on about 3 1/2 hole's
so it's gotta be quicker. then it was.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
13 Jan 2015 09:45 #658590 by zukdave
Well part's should be here in the morning and Friday
I'll drop the block off for the bore work and I should
get the port work done this weekend.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
14 Jan 2015 17:06 #658718 by zukdave
Got goodie's today.
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
16 Jan 2015 14:47 #658864 by zukdave
Got the block dropped off today and should start going back together
next weekend.
And let me get this out of the way Eric March 28th I'll be at the River bring ANY bike you have
and race me again. You talked shit about beating me on the pass's I missed the 1-2 shift on
otherwise you would NOT have beat me and you know it.
I've got $100.00 say's your a no show prove me wrong ?????????????????
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
