Drag strip trip.
10 Apr 2012 22:35 - 10 Apr 2012 22:39 #515129 by zukdave
Replied by zukdave on topic Drag strip trip.
Mark that motor's about the same as my gpz motor.
738 cc.
head wise I did this cut out stock
intake 650 vs gpz head.
Not sure on your cam number's but we're probably close.
No reason why at the factory 87 hp and 620 lbs suited
I can't run mid 12's other then this thing can't breath
on the little carb's but I'm fixxin that shit.
The 29's cleaned up nice.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 10 Apr 2012 22:39 by zukdave.
07 May 2012 23:13 - 08 May 2012 00:28 #520605 by zukdave
Injected wrote:
Attachment earlytimingslip.jpg not found
Let me up date this.
Last weekend went to the track with the new carbs
and played with the bike.
Best pass was.
60 ft. 1.8449 (blowin the tire off)
330 ft. 5.0374
1/8 mile 7.8142 AT 88.08
1/4 MILE 12.38 AT 102.83.
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 08 May 2012 00:28 by zukdave.
08 May 2012 07:54 - 08 May 2012 08:04 #520661 by LarryC
Replied by LarryC on topic Drag strip trip.
Nice improvement :)
Looks like a baffle of some sort in the pipe in the one photo. Yank it out.
Cam wise....if you're keeping compression moderate, duration should follow. Megacycle 471-10. If you're going full on race compression, Megacycle 471-20, for example are a couple of good grinds.
Least expensive way is 83 Gpz 750 cams as a drop in with OEM Pistons.
Larry C.
Last edit: 08 May 2012 08:04 by LarryC.
08 May 2012 08:46 #520669 by zukdave
Larry the motors an 83 gpz so I have those cam already.
As for the baffle its just the end plate off a baffle
not a full baffle.
Will be doing a sidewinder off a 900 modded to fit.
Commpression whys I plan on taking about 020 off the head,
degree the cams with a mild port job.
I think if I can get it to stop spinin the tire
through the 60 ft. it should go 12.20s or better
just need to work on the tune and set up some more.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • DoubleDub
  • Visitor
08 May 2012 17:33 #520777 by DoubleDub
Replied by DoubleDub on topic Drag strip trip.
Awesome! Huge improvement. Cool to see. :evil:
  • mark1122
  • Keep twisting it
08 May 2012 19:24 #520804 by mark1122
Replied by mark1122 on topic Drag strip trip.
Looks like fun. :)
did u try taking some air out of the tire?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
08 May 2012 21:29 - 08 May 2012 21:30 #520825 by zukdave
At about 20 lbs. there ain't much more to take out.
The 130 tire on the stock 2.15" rim's
sucked in and not using all the tread.
Calling Buchanan's spoke and rim in the morning
to see about a 3 1/2" maybe 4" black anodized alum.
rim and spoke set.
With the gpz swing arm and some offset sprockets
I can fit a five inch slick easily and 7" stuffed.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 08 May 2012 21:30 by zukdave.
08 May 2012 21:40 #520836 by LarryC
zukdave wrote: Larry the motors an 83 gpz so I have those cam already.
not a full baffle.
Those heads are pretty good stock for an 810 motor :)
Larry C.
08 May 2012 22:20 #520845 by zukdave
So you're saying don't mill the head and wait till I do the 810
and let the bigger bore rise the compression ?
Another question you think going to a larger dia.
header tube will help or hurt the power ?
Nobody makes a sidewinder to fit so was thinking a KZ900-1000
pipe cut to fit as a step header set up.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • wireman
08 May 2012 22:47 #520852 by wireman
Replied by wireman on topic Drag strip trip.
Bigger bore in itself wont do much compression wise,but an 810 piston that matches the gpz combustion chamber would definately help.
Id try a Skinnier rear tire to flatten contact patch if it were me anyway B)
  • wireman
08 May 2012 22:51 #520853 by wireman
zukdave wrote: At about 20 lbs. there ain't much more to take out.
rim and spoke set.
Is thew gpz 750 arm that much wider?
I dont remember the 81-82 arm with dual shocks being any wider than stock 900-1000 arm,a 3" rim and a 130 tire is usually about it in a stock 900/1000 arm anyway.
  • DoubleDub
  • Visitor
08 May 2012 23:50 #520880 by DoubleDub
+1 - if so...maybe I need to look at swapping one of those arms over...
