- Thank you received: 732
Old / cracked / otherwise unusable VM28SS (Z1) carb holders
- slmjim+Z1BEBE
We've commissioned some prototype dummy glass 'float bowls' from a local custom laboratory glassblower, and they vary a little in height, necessitating some vertical adjustability of racks.
We don't care about radial cracks that would cause vacuum leaks, only that there is no severe cracking around the outer periphery that would compromise the ability of the holders to support the weight of a rack without sagging, although mounting the holders 'upside-down' might be a workaround for that. Missing rubber vacuum port caps is OK. No vacuum port at all is OK. If in doubt, ID of the holders needed at the carb end is 32.5mm ~ 33mm. Prefer a matched set.
We will gladly pay shipping within CONUS.
This project is further experimentation in the development detailed in this thread:
www.kzrider.com/forum/3-carburetor/61368...n-setting-fuel-level
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
- sf4t7
- Thank you received: 348
See photos attached for the fixture I made to mount carb rack. I found just using the end two carb holders to hold the rack is simpler to align and level. (but still have four holes to bench sync slides) A small bar clamp holding the rack to the board is easier than trying to use hose clamps for the carb necks. More than likely you already have a fixture made.
If no one has some old holders to send, as an alternative some el cheapo chinese ones from evilbay with free shipping would work.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
- Thank you received: 1918
Great minds think alike. I need to drill the hole to do the bench sync.Just some suggestions:
- sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
- sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
I like the mods. Never thought about mounting the Auxiliary tank yo the stand.Btw Mikaw, my fixture was copied from yours and I added the legs to the top so I can flip it over to access the jets and floats
- slmjim+Z1BEBE
Perfect. Thank You!Your choice.
We'll ask Mods to share addresses.
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Thank you received: 2301
Done
Good Ridin'
slmjim & Z1BEBE
- slmjim+Z1BEBE
We replied to an email fromSlmjim, I have sent a couple emails and no reply. Have you received them. Hope you and your family are well.
<dock_manxx AT yahoo dot com>
on June 28. (The 'xx AT ' and 'dot' is our edit for your privacy).
Was that you?
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
