  • Page:
  • 1
VM Float Bowls & Throttle Shaft Grommets 02 May 2023 17:15 #884141
  • Nessism
  • Nessism's Avatar Topic Author
  • Away
  • Thank you received: 2672
I could use some of the subject listed parts.
Please email me at ness_ism_ AT sbc _ global DOT NET (remove spaces & underlines)
Thanks
VM Float Bowls & Throttle Shaft Grommets 02 May 2023 18:50 #884150
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1895
Like this? Float bowl gasket is rubber style, works geat for me (re-usable multiple times).
VM Float Bowls & Throttle Shaft Grommets 02 May 2023 19:08 #884152
  • Nessism
  • Away
 The throttle shaft grommet with the hole is what I need.  I've got a couple, but need more.
The gasket is not needed.  I need float bowls.  Some without cracked over flow tubes, or pitting in the bottom of the bowl from corrosion.  Two with the drain pointed left, and two pointed right.
VM Float Bowls & Throttle Shaft Grommets 02 May 2023 20:02 #884153
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
VM Float Bowls & Throttle Shaft Grommets 03 May 2023 05:45 #884170
  • Mikaw
  • Mikaw's Avatar
  • Away
  • Thank you received: 1853
I’m sure I have some, I’ll look this afternoon
  • Page:
  • 1
