  • Page:
  • 1
  • 2
1983 GPZ 750 Stock Airbox Wanted ! 02 Apr 2023 19:47 #882356
  • atownbrg
  • atownbrg's Avatar Topic Author
  • Thank you received: 0
Just acquired the bike. It came with pod filters, and after reading all the issues that can arise from pod filters, I really want to locate all the stock airbox parts as the bike came from the factory. I'm missing everything!
Please reply to forum or email
This email address is being protected from spambots. You need JavaScript enabled to view it.
Thanks!
1983 Kawasaki GPZ 750
1983 GPZ 750 Stock Airbox Wanted ! 03 Apr 2023 05:40 #882378
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
My usual MO is to search eBay with the factory part number. Sometimes you get lucky but usually you have to be patient.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: atownbrg
1983 GPZ 750 Stock Airbox Wanted ! 03 Apr 2023 06:03 #882380
  • JR
  • JR's Avatar
  • Thank you received: 429
A drill down on partzilla.com shows thst airbox was used on the 83, 84 and 85 gpz and zx 750s so that might help widen your search parameters. There are a few incomplete ones and 1 which looks mostly complete ($$$) on ebay at the moment. Search gpz750 airbox.
1983 GPZ 750 Stock Airbox Wanted ! 03 Apr 2023 10:41 #882404
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
search eBay item number: 134498325966
1983 GPZ 750 Stock Airbox Wanted ! 03 Apr 2023 10:46 #882405
  • atownbrg
Thanks for the tips! How important is it to try and get an airbox with the internal parts. Most airboxes I'm seeing on Ebay are only the outer housing.  Also are the metal side panels just for aesthetics?
Last edit: by atownbrg.
1983 GPZ 750 Stock Airbox Wanted ! 03 Apr 2023 11:00 #882406
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Looks almost complet and in top condition! eBay item number: 363613418352
1983 GPZ 750 Stock Airbox Wanted ! 03 Apr 2023 11:06 #882407
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
eBay item number: 304717340436
1983 GPZ 750 Stock Airbox Wanted ! 03 Apr 2023 15:59 #882438
  • JR
  • JR's Avatar
_ _ _ _ _ _ _ _ _ _ _ _ _
From your attachment you need the airbox cap #11012 for sure.
I'm thinking / guessing that items 13091A and 13091B are inner and outer frames for a reusable foam air filter 11013. If so then you could probably use a 1piece air filter like in my 1980 750E1.
Item #13091 the holder is usually incorporated into the bottom of the airbox - check photos - but if not this part is used in good number of models. Again Partzilla- kawasaki-year-model etc.
Think the piece below the holder is just a thick rubber washer.
Think #92071A may be an inlet for the Kawa Clean Air system which we didn't have in Canada and as many people in the US removed this and plugged the hole it may not be relevant
Cant place the "metal side panels" you mention. Perhaps these are bling for the shoulders of the airbox and have no other function ?
Last edit: by JR.
1983 GPZ 750 Stock Airbox Wanted ! 03 Apr 2023 16:21 #882441
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2675
A stock airbox is a beautiful thing.  Clean your carbs properly, make sure all the jets are the stock size, and you can be assured that the carburetor tuning will be PERFECT.
The following user(s) said Thank You: blipco
1983 GPZ 750 Stock Airbox Wanted ! 04 Apr 2023 12:47 #882501
  • atownbrg
JR, Thanks for giving me a rundown on the parts diagram pieces I was unsure about! Very helpful. I believe those metal side covers came with the earlier non gpz bikes that have different bodywork and are just for aesthetics. On those bikes the full sides of the airbox are visible whereas on the gpz's they somewhat tuck under the panel. There's even a third version I believe that don't use the metal side panels, but have molded in "stripes" that protrude. Ebay sellers don't necessarily know what they have mis identify what bikes they are meant for.
1983 GPZ 750 Stock Airbox Wanted ! 04 Apr 2023 15:23 #882507
  • atownbrg
Ok, I've become sort of a quick "expert" on the airboxes. The one that fits the bike is KHI A 034 . It mounts by a centrally located bolt facing towards the rear of the bike. Others have metal tabs that locate box on each side. Those are labeled as KHI A 019 and I believe found prior to '83.
1983 GPZ 750 Stock Airbox Wanted ! 07 Apr 2023 08:54 #882606
  • atownbrg
Airbox purchased on ebay. Not sure how to mark ad as "found"
  • Page:
  • 1
  • 2
