  • Page:
  • 1
78 kz1000 rebuild 06 Jan 2023 09:40 #878612
  • udder
  • udder's Avatar Topic Author
  • Thank you received: 0
Looking for web 110 grind cams, 28 smooth bore carbs and a gas tank.
78 kz1000 rebuild 06 Jan 2023 11:08 #878616
  • ronnieV
  • ronnieV's Avatar
  • Thank you received: 143
I have a set of 28s from 74/75 z1 900
78 kz1000 rebuild 06 Jan 2023 16:13 #878629
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2249
"Smoothbore" carbs are VM29's or VM33's.
Carburetor O-ring Kits For Sale: Mikuni VM & BS/CV, and Keihin CV34 (as used on KZ750E/H/N/Spectre, 400)
www.kzrider.com/forum/forum-index/faq-wi...owner-things-to-know
78 kz1000 rebuild 06 Jan 2023 17:28 #878630
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1561
The pumper you just posted are also 28mm just FYI
78 kz1000 rebuild 09 Jan 2023 08:26 #878685
  • udder
Yeah the 29 smoothbore are what I would like. Thanks for the correction.
78 kz1000 rebuild 31 Jan 2023 05:57 #879507
  • Wheelhop
  • Wheelhop's Avatar
  • Thank you received: 201
There is a set of 29 vm Smoothbore carbs on Chicago Craigslist for sale (actual location is Lowell, IN)
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
78 kz1000 rebuild 31 Jan 2023 09:44 #879524
  • Buzz Nichols
  • Buzz Nichols's Avatar
  • Thank you received: 77
I've also got a '78 KZ1000 and, based on my research, it seems like the VM 29's (which were the go-to for extra HP back in the day) are now rare and expensive. A set of RS34's can likely be found cheaper, and will give a bigger boost while requiring less fiddling.
As always, I defer to the input of the many members of the forum who know way more than I do about these machines.
1978 KZ1000 LTD
78 kz1000 rebuild 31 Jan 2023 14:28 #879531
  • DFIGPZ
  • DFIGPZ's Avatar
  • Thank you received: 115
Correct you are way farther ahead with 34mm Flatslides
1984 750 Turbo
78 kz1000 rebuild 01 Feb 2023 05:22 #879559
  • willemZ900
  • willemZ900's Avatar
  • Away
  • Z1B 4 ever
  • Thank you received: 37
Unless you want your bike time period as i did with mine Z1. I have the VM29 pumper smooties for several years now and the bike performs very well.
78 kz1000 rebuild 01 Feb 2023 07:35 #879582
  • Mikaw
  • Mikaw's Avatar
You have a set of 29 Smoothbore with accelerator pump option. Very cool. I have a set of 33SB with pump bowls but I don’t think the linkage is complete. Mine were bored out. One day I’ll rebuild them.
Last edit: by Mikaw.
  • Page:
  • 1
