  • Page:
  • 1
Z12 00 #4 carb, 1979 KZ1000 LTD grab bar 21 Nov 2022 19:20 #877062
  • LukasLee
  • LukasLee's Avatar Topic Author
  • Away
  • Thank you received: 1
I'm looking for the #4 carb body of the Z12 rack, also grab bar for a '79 1000 LTD. Thanks
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
Z12 00 #4 carb, 1979 KZ1000 LTD grab bar 22 Nov 2022 06:18 #877068
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1562
Post a picture of the carb rack please. Are they 26mm or 28mm. The LTD grab bar is pretty rare
Z12 00 #4 carb, 1979 KZ1000 LTD grab bar 23 Nov 2022 06:25 #877090
  • Moose1800
  • Moose1800's Avatar
  • Thank you received: 140
I'm also in need of an LTD grab bar, theres one on ebay for a crack head price of $350.....no thanks
Z12 00 #4 carb, 1979 KZ1000 LTD grab bar 23 Nov 2022 17:09 #877109
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 280
I do not want to mislead anyone on this but at pretty sure the carb set ID Z12 00 is a set of vm26ss carbs.  I think they were used on the kz900 bikes.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Z12 00 #4 carb, 1979 KZ1000 LTD grab bar 23 Nov 2022 18:06 #877116
  • Mikaw
  • Mikaw's Avatar
If the OP will reply, I’m willing to pay it forward. Wheelhop, sent me several parts to Frankenstein a set of carbs together. He said to hang on to the extras. If I have what he needs I’ll help him out, because of Wheelhops generosity.
The following user(s) said Thank You: Nessism, gd4now
Z12 00 #4 carb, 1979 KZ1000 LTD grab bar 23 Nov 2022 18:49 #877119
  • LukasLee
  • Away
Sorry for the late reply. Turns out I don't need the carb after all, the slide was stuck in the carb body, the previous owner tried prying it out with a screw driver flairing the bottom of the slide a little. After I sanded the flair off it works good.
Does anyone know if the grab bar from the non LTD models will fit, I know it won't be as tall but am curious if the mounting points are the same ?
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
Z12 00 #4 carb, 1979 KZ1000 LTD grab bar 23 Nov 2022 19:01 #877120
  • LukasLee
  • Away
I saw that ad too, I had a similar thought.
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
Z12 00 #4 carb, 1979 KZ1000 LTD grab bar 23 Nov 2022 19:32 #877121
  • Mikaw
  • Mikaw's Avatar
Yes. An “A” model seat stay will bolt on without modifications.
Z12 00 #4 carb, 1979 KZ1000 LTD grab bar 25 Nov 2022 11:42 #877181
  • LukasLee
  • Away
Ok thanks, I may have to go that route if I can't find one for a LTD.
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
  • Page:
  • 1
