  • Page:
  • 1
KZ750CSR (M1) speedo and rev counter chrome trim cups wanted 19 Mar 2022 21:52 #864063
  • summerider
  • summerider's Avatar Topic Author
  • Thank you received: 1
Hi, I'm looking for a pair of chrome trim cups that go under the gauges of a 750CSR or a place that I can get hold of these. Alternatively, can anyone suggest a pair of gauges that would be compatible with a KZ750CSR please?
KZ750CSR (M1) speedo and rev counter chrome trim cups wanted 20 Mar 2022 08:27 #864078
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
Howdy. The diagrams at Partzilla have cross-reference info. www.partzilla.com/catalog/kawasaki/motor...twin-kz750-m1/meters
The following models use the same basic meter assy, but the speedo & tach features can vary. The 750-CSR has a lower redline.
A quick way to check for yourself is to x-ref the meter bracket >> if the meter bracket is the same, then everything else from the models listed will physically swap.  I have the 650-CSR & already checked into this stuff. hee.
1983-84 KZ750K Twin Ltd Belt.
These should be a close match if not the same as the 750-CSR. redline should be the same. the 84 model was sold in Canada.
81-83 KZ650-CSR.  80-83 KZ750H Ltd.  81-82 KZ1000M CSR.
these are chain drive models. some 750-4 Ltds are shaft drive w different meters. 750-CSR has lower redline.
The following user(s) said Thank You: summerider
Last edit: by martin_csr.
KZ750CSR (M1) speedo and rev counter chrome trim cups wanted 21 Mar 2022 13:38 #864135
  • summerider
Thank you Sir, and very nice photos of your 650 as well.
  • Page:
  • 1
