  • Page:
  • 1
  • 2
KZ1000 Sprocket Carrier 07 Mar 2022 07:35 #863301
  • Mr. E
  • Mr. E's Avatar Topic Author
  • Thank you received: 14
Good Morning all,
I am looking to buy a  drive chain sprocket carrier off the rear wheel of a kz1000 it is an 18" Spoked wheel with stock hub
Thanks - Mr.E
1981 KZ750 Chopper, 1975 KZ400 , 1984 GPZ750 track build , Res 1977 kz1000a ,1977 kz1000a ...ect.
Last edit: by Mr. E. Reason: No Coffee = Poor Spelling...
KZ1000 Sprocket Carrier 09 Mar 2022 08:02 #863462
  • Mr. E
Didnt realize how rare these were...
Sold my soul and purchased the last one off evilbay.
-End Thread-
KZ1000 Sprocket Carrier 09 Mar 2022 13:51 #863489
  • DFIGPZ
  • DFIGPZ's Avatar
  • Thank you received: 122
are you looking for one for use with spoke wheel for disc brakes ?
1984 750 Turbo
KZ1000 Sprocket Carrier 09 Mar 2022 20:08 #863512
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
Are the sprocket carriers very different between the KZ1000 spoke wheels and the KZ1000 mag wheels?  Are they not at all compatible?  I've never had a spoke wheel bike, but I figured they would be similar.
My dad's '74 Z1
'00 ZRX1100
KZ1000 Sprocket Carrier 10 Mar 2022 06:10 #863536
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1853
According to Partzilla Exchange, part number 42008-034 sprocket carrier / crush drive only fits 77-80 kz1000 “A” models.
KZ1000 Sprocket Carrier 11 Mar 2022 20:30 #863614
  • Mr. E
I am, I just bought one off ebay and it  doesn't fit. Bummed.
KZ1000 Sprocket Carrier 11 Mar 2022 20:31 #863615
  • Mr. E
Yes I am
KZ1000 Sprocket Carrier 13 Mar 2022 13:32 #863749
  • Mr. E
Found and this challenge is done.
KZ1000 Sprocket Carrier 13 Mar 2022 14:02 #863752
  • DOHC
  • DOHC's Avatar
I think it's just 77 and 78.  The "A" model bikes had mag wheels in 79 and 80.
I would have guessed that the different part number for the mag wheel sprocket carrier 42008-040 was just because it was painted black around the edge.  Or maybe that's the case for the Z1R specific one, 42033-1005?
But now that I look at it, the spoke wheel hub uses a different shock damper (42014-028) than the mag wheels bikes (42014-033) which suggests they are not compatible.
Mr. E, if you ended up with the two different kinds can you point out the difference?
My dad's '74 Z1
'00 ZRX1100
KZ1000 Sprocket Carrier 13 Mar 2022 16:43 #863762
  • Mr. E
Ok, here is a quick shot at the ones yall may run into, I can get better shots post cleaning later. But the first sprocket is the correct one for the 18" spoked wheel with disc brake, the identifying markers I notice is the casting fingers you can see through the sprocket holes. The fingers on the backside are thicker than others. Casting code 041
The second sprocket is for the 18" spoked drum rear wheel. This has a noticeably wider sprocket bolt pattern and the cast wall that connects them. It also has a circular cast  inner ridge that is noticeable . It will be too large to fit the disc hub. Casting code 031
Last edit: by Street Fighter LTD.
KZ1000 Sprocket Carrier 13 Mar 2022 18:40 #863771
  • Mikaw
  • Mikaw's Avatar
The second hub, for the 900 drum wheel comes in two versions that I know of. As you pictured with the rib down in the recess and one with that said rib which is the earlier version.
The following user(s) said Thank You: Mr. E
KZ1000 Sprocket Carrier 15 Mar 2022 09:42 #863828
  • Mr. E
Here are cleaner pictures of the correct one should anyone like to save them. Casting 041
  • Page:
  • 1
  • 2
