  • Page:
  • 1
  • 2
own Fasteners 1977 kz1000 a1 30 Jan 2022 06:35 #861442
  • Gdizard
  • Gdizard's Avatar Topic Author
  • 12/03/1954
  • Thank you received: 2
ONE MORE QUESTION
WHICH OTHER KAWASAKI MODELS USED SAME PARTS AS KZ1000? I WOULD GUESS THAT KZ750,KZ650 USED SIMILAR SIZE PARTS
own Fasteners 1977 kz1000 a1 30 Jan 2022 09:06 #861463
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 245
Look around for a plater, you may have to ship.  No way its cheaper buying new hardware.
I just did a quick clean in a tin can with mineral spirits and went over each piece with a jewelers file if needed.  The plater will clean them before the process.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
own Fasteners 1977 kz1000 a1 30 Jan 2022 10:40 #861465
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1849
Similar. Find a zinc plater. Tripp platting in Buffalo NY is who I use. I degrease them, touch up any wrench boogers. I send them to be blasted (Glass bead) then my blaster ships them to Tripp for me. As Kidkawie says you get volume discounts.
own Fasteners 1977 kz1000 a1 30 Jan 2022 12:04 #861477
  • Gdizard
  • 12/03/1954
THANK YOU !
HAVE YOU SEEN SOME OF THE PANHEAD SCREWS WHERE THEY SEEM TO BE IN A STATE OF CORROSION AND THEY ARE TO SMALL TO DEAL WITH ?
Or are you able to use everything?
own Fasteners 1977 kz1000 a1 30 Jan 2022 12:14 #861479
  • Mikaw
  • Mikaw's Avatar
As for cross head, pan screws, I base them on the appearance. If the head is all boogered up from not using JIS tools they get replaced. If the head is good then overall condition. Some cross heads are just not worth it. Buy new. If you’re counting rivets, check the cross heads your replacing for a dot on the head. They are still available with the dot. Not all cross heads had the dot.
own Fasteners 1977 kz1000 a1 11 Feb 2022 05:08 #862118
  • Gdizard
  • 12/03/1954
thank you
   How much would we expect to pay for glass beading?
Greg
  • Page:
  • 1
  • 2
