Front Wheel Assembly fir 1979 Kawasaki LTD1000
20 Apr 2021 03:03 #847077 by Spade
Looking for a OEM or mint front mag wheel assembly for my 1979 LTD 1000. Part # 41073-1040. Also asking for help to determine if the stock rim from a 1977 LTD1000 would fit. The part # for the 1977 is 41089-005. I found one listing on Ebay for each of these part #'s but would appreciate any advice from this forum to confirm that either rim will fit my 1979 LTD
  • hardrockminer
20 Apr 2021 05:01 #847078 by hardrockminer
Replied by hardrockminer on topic Front Wheel Assembly fir 1979 Kawasaki LTD1000
The numbers you're quoting are for entire assemblies.  They are different numbers so something about the assembly is different.  You would have to go through each item in the assembly to determine exactly what is different.  I suspect the rim from any LTD between 1976 and 1980 will fit your bike.  When I look at Partzilla I can see that the B1 rim and the B2/B3/B4 rims are still available.  Interestingly, so are the OEM balance weights, which are different from the new style.
I suggest you order the B2 assembly because that is the same number as your B3 and my B4.
  • DOHC
  • Those Doe-Hawks really go!
20 Apr 2021 06:08 - 20 Apr 2021 06:08 #847080 by DOHC
hardrockminer post=847078When I look at Partzilla I can see that the B1 rim and the B2/B3/B4 rims are still available.
It will let you add them to your cart, but they say "not available" in the name.  I think those are long gone.
I would avoid the '76 LTD, as those are Morris wheels and might require different hardware or something.
I agree that the 77-80 LTD front wheels are all likely to fit and work fine.  They should all be Enkei 19" 7-spoke mag wheels, and it looks like they all came with tubes.
It's hard to know why the part number changed.  It could be some small change to the wheel itself (thickness, certification, markings, etc.), or as hardrockminer said it could be a change to any of the other parts in the assembly.
My dad's '74 Z1
'00 ZRX1100
Last edit: 20 Apr 2021 06:08 by DOHC.
20 Apr 2021 08:57 #847090 by Mikaw
No eBay APP ID and/or Cert ID defined in Kunena configurationThis one is nice. Johnny’s is reputable place.
  • DOHC
20 Apr 2021 11:27 - 20 Apr 2021 11:28 #847098 by DOHC
Does it need to be mint, or just OEM?  I have one that has a date code of 13 79 (13th week?), so it could be from a '79.  It's been painted, so not mint.  But it has a brand new MX tire on it from the doofus I bought it from.  :)  PM me if you're interested.
My dad's '74 Z1
'00 ZRX1100
  • Last edit: 20 Apr 2021 11:28 by DOHC.
