VM33 smoothbore 23 Oct 2020 06:58 #837547
  • Mikaw
  • Mikaw's Avatar Topic Author
  • Thank you received: 719
Parts hunting has been good to me lately. About a week ago I scored another set of 33 Mikuni smoothbore for 150.00 shipped... I have lots of extra parts now, so I started the rebuild process. I found 3 out of the 8 brass floats with the outboard side Concave. All the others are convex. Are they still useable or am I lucky I have 5 out of 8 that are good? Also two of the bodies have a needle bearing pressed into the throttle shaft bore. I don’t want to remove it for fear of damage. Will it be ok to soak in Berryman’s
VM33 smoothbore 23 Oct 2020 08:08 #837558
  • asphalt900
  • asphalt900's Avatar
  • Thank you received: 66
Those are finicky carbs Matt and no ports for syncing and the bigger manifolds didn't have them. I had a set years ago that the piece was cut-off the bracket just like yours. It's a push/pull set-up and for some reason people like to cut-off the return boss? Maybe they are loosing weight to go faster, ha. Make sure to replace the gasket under the removable slide holder or you won't get a proper signal for pilot system.
VM33 smoothbore 24 Oct 2020 11:13 #837620
  • Mikaw
The first carb body is out of the dip and bearing is fine.
Asphalt900, I see the manifolds are missing the vacuum sync port. This could be a workaround. They could be tapped for a port.
Attachment 986C5AB9-C1A9-418D-A8D2-AC2C827EDD88.jpeg not found
VM33 smoothbore 24 Oct 2020 11:47 #837622
  • DOHC
  • DOHC's Avatar
  • Away
  • Those Doe-Hawks really go!
  • Thank you received: 225
And then you'd also be set up to add nitrous. :evil:
'78 Z1-R in blue, '78 Z1-R in black, '78 Z1-R in pieces
'95 GPZ1100 (sold) , '00 ZRX1100
VM33 smoothbore 25 Oct 2020 06:28 #837678
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 174
Matt needs nitrous like a sailor needs a bar in Bangkok.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
VM33 smoothbore 25 Oct 2020 08:17 #837683
  • Mikaw
Rick H.
So True!
VM33 smoothbore 21 Nov 2020 16:26 #838729
  • Mikaw
Making a little progress on the 33’s. This is a combination of two sets into one rack.
They have two different style of screw holding the jet block to the main body.
Two carbs have machine button heads and two have counter sunk heads. Sense I can’t cant add meterial to them I’m going to counter sink them.
I ordered new screws from Jets R Us.
My question is what is the counter sink angle
Last edit: by Mikaw.
VM33 smoothbore 24 Nov 2020 09:20 #838847
  • Mikaw
Without any answers I dove into the all knowing internet and think I found the counter sink angle. Appears to be 80-82 degs. Ordered a 1/4 x 82deg 6 flute countersink.
VM33 smoothbore 26 Nov 2020 07:50 #838973
  • Rick H.
  • Rick H.'s Avatar
Mikaw: I would try your countersink on something unimportant when you get it and see how the angle lines up with the jet. A bit of machinists dye or even a Sharpie pen may help see how the angle fits the jet.
Rick H.
Rick H.
VM33 smoothbore 13 Dec 2020 17:24 #839987
  • Mikaw
Maybe a mod can move this to a project category.
Chipping away at the 33’s rebuild. Waiting the last few washers and screws. The jet holder fixing screw areas have been countersunk, I got the float needles and seats polished up. The jets are in the Berrymans for the night.
VM33 smoothbore 13 Dec 2020 18:24 #839991
  • SWest
  • SWest's Avatar
  • Moderator
  • Thank you received: 2042
LOOKS GOOD B)
Opinions expressed by me do not reflect those of the the staff or members
VM33 smoothbore 26 Dec 2020 15:05 #840612
  • Mikaw
Waiting on the last couple caskets from Jets-R-Us. I think evey thing is cleaned and some even polished. I found the ID of the fuel transfer tubes fit nicely over some dremel attachments, I couldn’t resist.
