  • Page:
  • 1
  • 2
TOPIC: Z1 KZ 650/1000 Trip Meter Knob
Z1 KZ 650/1000 Trip Meter Knob 06 Jul 2019 13:58 #807076
  • SWest
  • SWest's Avatar Topic Author
  • Moderator
  • Moderator
  • Thank you received: 1753
Speedo works well, just need the knob. Anyone have one laying around? :unsure:
Opinions expressed by me do not reflect those of the the staff or members
Z1 KZ 650/1000 Trip Meter Knob 06 Jul 2019 16:41 #807086
  • seanbarney41
  • seanbarney41's Avatar
  • Member
  • Member
  • '79 kz1000 LTD '75 Honda CB750
  • Thank you received: 10
I have a smashed speedo but I don't remember if the knob is still there. I will have to dig it out and check...might take me a few days.
Z1 KZ 650/1000 Trip Meter Knob 06 Jul 2019 18:05 #807092
  • SWest
  • Moderator
  • Moderator
Thanks, let me know.
Z1 KZ 650/1000 Trip Meter Knob 07 Jul 2019 06:59 #807114
  • asphalt900
  • asphalt900's Avatar
  • Member
  • Member
  • Thank you received: 29
Good Morning Steve! Is it the early Z knob with the set screw or the later style?
Z1 KZ 650/1000 Trip Meter Knob 07 Jul 2019 07:18 #807115
  • SWest
  • Moderator
  • Moderator
It's the early one but no set screw. It's a fine reverse thread.
Z1 KZ 650/1000 Trip Meter Knob 07 Jul 2019 07:38 #807116
  • asphalt900
  • Member
  • Member
Interesting that it actually got lost? Usually at worst they unthread but are retained by the slot in the cone cover. Any-hoot I attached some photos of the two different styles. LH thread pitch/diameter is the same on both.
Z1 KZ 650/1000 Trip Meter Knob 07 Jul 2019 09:10 #807119
  • SWest
  • Moderator
  • Moderator
Didn't have the cover on. Mine didn't have the set screw.
Z1 KZ 650/1000 Trip Meter Knob 07 Jul 2019 17:04 #807142
  • seanbarney41
  • Member
  • Member
Yeah, I got the one without the set screw...so it looks like there is a little jam nut on there that is inside the gauge? I couldn't figure out how to get it off. Knowing for sure it is lh thread helps. SWest, I could send you the whole gauge. It was damaged in a crash. What do you want to pay for such a thing?
Z1 KZ 650/1000 Trip Meter Knob 07 Jul 2019 17:09 #807143
  • SWest
  • Moderator
  • Moderator
What are you asking? Pic?
Z1 KZ 650/1000 Trip Meter Knob 07 Jul 2019 17:14 #807144
  • asphalt900
  • Member
  • Member
Hey buddy just to be sure. Peer down thru the hole and see if You have a small brass lock nut, this is a sure indication of the "later" speedo. See Photos. The early instruments did Not utilize a jam nut, later gauges did. As per photos the extra length of the threads made it possible to use the jam nut. Sometimes the brass nut will vibrate out but since you stated you could of just misplaced it? I'm just covering all bases to make sure You receive the correct item. And did I mention it's Yours, either version. I don't do a lot of forum stuff, too busy. Still like to help out where I can, Love these ole' vintage beasts. Let me Know, Clay
Z1 KZ 650/1000 Trip Meter Knob 07 Jul 2019 17:45 #807145
  • SWest
  • Moderator
  • Moderator
Thanks. The one I have has the short shaft. I didn't notice a lock nut on them. The one I had had a skirt on the bottom like one you have.
Here's a bad pic of one I'd taken apart for the guts.
Z1 KZ 650/1000 Trip Meter Knob 07 Jul 2019 18:10 #807146
  • asphalt900
  • Member
  • Member
OK this might be better to Help. I'll send both versions, just send back what you don't use. Just need some sending info?
Z1 KZ 650/1000 Trip Meter Knob 07 Jul 2019 20:31 #807149
  • SWest
  • Moderator
  • Moderator
Do you have pay pal? I'll send $10 for postage and PM you with my address and you can reply with your pay pal if you have one.
Thank you
Z1 KZ 650/1000 Trip Meter Knob 08 Jul 2019 01:31 #807152
  • asphalt900
  • Member
  • Member
Got Your PM, will post today. Just a cleaver tip if You like to experiment. Take the 1/10 white(beige now) register wheel off left-over odometer register shown in photo and cover it in the product shown. Cover with product and put it in a sandwich baggie, put it outside in the sun. Let sit all day. Rinse product off with water. Ever so gently I use a q-tip wiping across numerals. Will be much whiter without removing numerals. Knob selection boxed-up and ready to ship.
Z1 KZ 650/1000 Trip Meter Knob 08 Jul 2019 09:20 #807168
  • asphalt900
  • Member
  • Member
See Steve, way too much stuff. One Tupperware container (1of2) and the cut glass I was referring to. Won't ever use it all and cannot take it with me.
Z1 KZ 650/1000 Trip Meter Knob 08 Jul 2019 10:58 #807169
  • asphalt900
  • Member
  • Member
On it's way to You Steve. Tracking#9500 1140 0531 9189 3059 10. Ticket states 7/11 Thursday as delivery date
Z1 KZ 650/1000 Trip Meter Knob 08 Jul 2019 11:26 #807171
  • SWest
  • Moderator
  • Moderator
Thank you much my friend. Do you have a tach I can convert to my Z1b case? Thinking on buying another face plate.
Z1 KZ 650/1000 Trip Meter Knob 08 Jul 2019 11:48 #807175
  • asphalt900
  • Member
  • Member
You are very Welcome!! That's why we are all here, to Help. No problem with the conversion. Tach drives from a KZ650, KZ900, KZ1000 up to 77 all will work. There are 3 different styles but you cannot tell it once they are assembled. And they all share the calibration and 9000rpm. As far as the purchase of the repop face might I give you a bit of advice? They work wonderful BUT be careful when tightening the two retaining screws!! The plastic is MUCH more brittle than oem. I use them but i drill out the existing 2 screw holes with a 1/8" twist bit and make collars that are inserted into the holes just proud of the surface, see photo. The aftermarket faces are generally around 2.2-2.5mm thick.
Z1 KZ 650/1000 Trip Meter Knob 08 Jul 2019 11:55 #807177
  • asphalt900
  • Member
  • Member
Oh and one more thing to consider being it is a 75 Z. I have seen two versions. Some share the beveled opening for mileage and odometer and some are straight cut openings like KZ900-1000. Those beveled 10mph increment faces are not available, and I've tried calling companies that make faces. Cost would of been prohibitive because of the Min. lot numbers.
Z1 KZ 650/1000 Trip Meter Knob 08 Jul 2019 12:05 #807179
  • asphalt900
  • Member
  • Member
That is just a tip on the speedo just incase you will be doing a matching set. Also have a trick for doing the upper can, black gloss, that rivals the oem look if you are interested. Something anybody can do, provided the spouse doesn't mind you using the oven for a spell. Same goes for the switchblocks I do.
  • Page:
  • 1
  • 2
