  • Page:
  • 1
TOPIC: Z1 1972-early 74 Float Bowls and Main jet covers
Z1 1972-early 74 Float Bowls and Main jet covers 19 May 2019 00:09 #804135
  • asphalt900
  • asphalt900's Avatar Topic Author
  • Member
  • Member
  • Thank you received: 35
Working on an early Z1 set of Mikuni Stock VM28mm (1470) carbs for a friend. Went to remove the big nut on bowls to find someone had JB Welded them on. So i'm in need of a decent set of 4. No heavy pitting/corrosion inside bowls Please. Thank-You, Clay
Z1 1972-early 74 Float Bowls and Main jet covers 20 May 2019 18:34 #804279
  • baldy110
  • baldy110's Avatar
  • Member
  • Member
  • Thank you received: 437
Use a propane torch to soften the epoxy.
Z1 1972-early 74 Float Bowls and Main jet covers 21 May 2019 06:56 #804298
  • asphalt900
  • Member
  • Member
Thanks Baldy! I know jb looses it's composure at about 550 Deg, the nuts are already out. Problem is the threads are missing in bowls. Someone used some 22mm headed main jet covers from, what looks like, trx300 quad or similar. That would of been ok being thread diameter and pitch is the same but they are stripped of threads also.
Z1 1972-early 74 Float Bowls and Main jet covers 29 Jun 2019 05:25 #806664
  • asphalt900
  • Member
  • Member
Bump. Still looking to purchase, anyone?
Z1 1972-early 74 Float Bowls and Main jet covers 02 Jul 2019 11:20 #806855
  • old greek
  • old greek's Avatar
  • Member
  • Member
  • Thank you received: 16
You can try calling Jim who owned Redline Cycle, he closed down the shop & works out of his home now, dont know if he kept the same #...(847) 675-2020, ...if he don't have the parts he might be able to steer you in the right direction.......Pete
Z1 1972-early 74 Float Bowls and Main jet covers 02 Jul 2019 16:12 #806869
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Member
  • Member
  • Thank you received: 242
We'll be at Mid-Ohio later this week. If we see any, what are you willing to pay so we don't get stuck with them?
Good Ridin'
slmjim & Z1BEBE
1973 Z1 x2
1973 Z1 "The Wounded Z" Resto project
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Z1 1972-early 74 Float Bowls and Main jet covers 03 Jul 2019 10:39 #806913
  • old greek
  • Member
  • Member
You can also try here....... www.redlinecycles1.com/ Pete
Z1 1972-early 74 Float Bowls and Main jet covers 04 Jul 2019 09:39 #806942
  • asphalt900
  • Member
  • Member
Thanks old greek. I called the number but it was no longer in service. I see You also added a web address since I last checked, i'll try it tomorrow. Slmjim does 150.00USD sound like enough of a bargaining chip? Feel free to make some money for yourself if someone just throws a set your way. Bowls and drain nuts, be nice to finish them up. On that note here is a trick I've been doing for years on these Mikuni carbs, no more brown staining.
Z1 1972-early 74 Float Bowls and Main jet covers 04 Jul 2019 10:42 #806948
  • old greek
  • Member
  • Member
A little more than you want to spend, but you'll have spare parts...... .....Pete
Z1 1972-early 74 Float Bowls and Main jet covers 04 Jul 2019 11:03 #806949
  • asphalt900
  • Member
  • Member
Yea that's Mike from Indiana. Those are for the late 74-75 Z bowls, small drain screws, won't work on earlier Z carbs. Choke p/u is in a different location and the emulsion tube is a longer hex on the earlier so the main jet would probably bottom out. Thanks for looking though!!
Z1 1972-early 74 Float Bowls and Main jet covers 04 Jul 2019 11:11 #806950
  • asphalt900
  • Member
  • Member
Here a photo of the Z1, KZ900 and KZ1000 emulsion tube, aka jet holder, styles used. Left (early) to right (late)
Z1 1972-early 74 Float Bowls and Main jet covers 04 Jul 2019 12:21 #806952
  • old greek
  • Member
  • Member
That sucks !!!
Z1 1972-early 74 Float Bowls and Main jet covers 04 Jul 2019 12:53 #806955
  • asphalt900
  • Member
  • Member
Not a problem, i'll find some. Mike will probably send those, if they don't sell, you showed to do my thing to them anyway. I re-plate all the metal bits and other carb stuff for him on occasion.
Z1 1972-early 74 Float Bowls and Main jet covers 05 Jul 2019 09:54 #807005
  • old greek
  • Member
  • Member
Nice work...Pete
Z1 1972-early 74 Float Bowls and Main jet covers 08 Jul 2019 06:09 #807160
  • slmjim+Z1BEBE
  • Member
  • Member
asphalt900 wrote: Here a photo of the Z1, KZ900 and KZ1000 emulsion tube, aka jet holder, styles used. Left (early) to right (late)
That's a good reference pic.
We'd already left for Mid-OH when you posted your reply. Sent a reply to your PM a few minutes ago.
Good Ridin'
slmjim & Z1BEBE
1973 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Z1 1972-early 74 Float Bowls and Main jet covers 12 Jul 2019 10:03 #807435
  • asphalt900
  • Member
  • Member
Pete here is what the bowls look like. This is the rare first style ribless Mikuni VM28 Z1 1470's. All replated metal bits and ready to be wet tested.
The following user(s) said Thank You: old greek
  • Page:
  • 1
