  • Page:
  • 1
TOPIC: Two connectors and/or pins for Z1 center wiring area & rectifier.
Two connectors and/or pins for Z1 center wiring area & rectifier. 03 Apr 2019 05:57 #801437
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar Topic Author
  • Member
  • Member
  • Thank you received: 225
In need of:
1) defective or broken rectifier so we can repair a good rectifier that's had it's pin connector modified with an incorrect Molex connector. All we really need is the connector, pins and wiring back to as close to the rectifier body as possible. A whole connector with associated wiring that has been cut or de-soldered from a rectifier assy. would be fine.
2) The brown male connector & pins for the main wiring harness, and the brown female connector and pins for the center harness 26002-035. Either or both would be of help. See below for pics.
Thanks for looking
Good ridin'
slmjim & Z1BEBE
1973 Z1 x2
1973 Z1 "The Wounded Z" Resto project
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Two connectors and/or pins for Z1 center wiring area & rectifier. 03 Apr 2019 14:41 #801461
  • DFIGPZ
  • DFIGPZ's Avatar
  • Member
  • Member
  • Thank you received: 89
Question are you doing a full blown restoration ? if not I would convert to new style rectifier regulator plug and play much better set up than the old style. I have done several on 73,74 & 75 Z1s.
1984 GPZ 1100
1170 wiesco 10.5 cr
Larry Cavanaugh head
Bored Throttle bodies
Web .415in cams
Kerker K2 with comp baffle
RC Hp inj
Pogue Adj Regulator
VITON VALVE SEALS $22.00 SET OF 8 SHIPPED TO LOWER 48 PM ME.
Two connectors and/or pins for Z1 center wiring area & rectifier. 04 Apr 2019 08:13 #801502
  • slmjim+Z1BEBE
  • Member
  • Member
We're doing a full resto to stock. We want it to be a potential buyer's choice to have an electrically stock Z1 or one that's been modified, even if a mod is plug-n-play. Originality is important to many buyers of Z1's.
Good Ridin'
slmjim & Z1BEBE
1973 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Two connectors and/or pins for Z1 center wiring area & rectifier. 04 Apr 2019 08:51 #801509
  • martin_csr
  • martin_csr's Avatar
  • Member
  • Member
  • Thank you received: 1043
I guess you don't know the name of that connector or what type it is or the mfg? I tried CycleTerminal but didn't see anything like that.
Last edit: by martin_csr.
Two connectors and/or pins for Z1 center wiring area & rectifier. 04 Apr 2019 09:25 #801511
  • SWest
  • SWest's Avatar
  • Moderator
  • Moderator
  • Thank you received: 1753
I'd get this.
z1parts.net/center-wiring-harness-battery-z1-900-kz900-kz1000/
As for the regulator I may still have one I bought off a Z1 in 98. I'll look.
The rectifier was shot so I used one from a XS 650. It was larger and not what you want.
Finding good useable 40+ year old parts may be a problem.
I understand why you want original parts but the old ones had issues where the aftermarket ones are of better design.
z1parts.net/z1-900-regulator-21066-013/
No listing for just the rectifier and regulator separately.
Opinions expressed by me do not reflect those of the the staff or members
The following user(s) said Thank You: slmjim+Z1BEBE
Two connectors and/or pins for Z1 center wiring area & rectifier. 04 Apr 2019 15:40 #801529
  • bluezbike
  • bluezbike's Avatar
  • Thank you received: 105
I have this if it helps. It's off a '75 frame I will probably never build
79 KZ 1000 LTD
Last edit: by bluezbike.
Two connectors and/or pins for Z1 center wiring area & rectifier. 05 Apr 2019 06:25 #801569
  • slmjim+Z1BEBE
  • Member
  • Member
SWest wrote: I'd get this.
Thanks Steve. That gets us part way there. We'd still need the brown male connector from an original main wiring harness to mate up with the brown female connector on the center wiring harness.
It's the rectifier connector we need if you still have the bad one.
We'll be moving to modern reg/recs on our stable of Z1's as time & money permit. We're flipping this bike, so originality is preferred.
Good Ridin'
slmjim & Z1BEBE
1973 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Two connectors and/or pins for Z1 center wiring area & rectifier. 05 Apr 2019 07:00 #801573
  • SWest
  • SWest's Avatar
  • Moderator
  • Moderator
Looks like blue has what you need or most of it. The brown and white connectors were fried on my old loom. I'll have to dig for the regulator but I'm not sure the connector is still with it. In 13 Z1E had all the connectors. Maybe send Jeff a message asking him where you can find them. Let us know if he does, I'd like to have a couple myself.
Last edit: by SWest.
Two connectors and/or pins for Z1 center wiring area & rectifier. 13 Apr 2019 06:25 #802020
  • SWest
  • SWest's Avatar
  • Moderator
  • Moderator
Looks like this is what you're looking for. It has everything you need.
bluezbike wrote: I have this if it helps. It's off a '75 frame I will probably never build
The following user(s) said Thank You: bluezbike
  • Page:
  • 1
