  • Page:
  • 1
TOPIC: WTB: Z1-R engine or cases, KZT00DExxxxxx
WTB: Z1-R engine or cases, KZT00DExxxxxx 24 Jan 2019 20:17 #797453
  • 79MKII
  • 79MKII's Avatar Topic Author
  • Member
  • Member
  • Love Them Kaws!
  • Thank you received: 48
Looking for a "numbers matching" set of cases for my Z1-R having frame number 002824. Would consider a complete engine if the price is reasonable. I have a great running Z1-R engine now but I recently realized that the numbers are too far off to be considered "correct". The engine is about 1600 lower than the frame. Thanks!
The Kaw List:
WTB: Z1-R engine or cases, KZT00DExxxxxx 24 Jan 2019 20:44 #797455
  • Member
  • Member
  • Thank you received: 2415
What exactly is the engine's full serial number? Ed
WTB: Z1-R engine or cases, KZT00DExxxxxx 25 Jan 2019 03:55 #797462
  • 79MKII
  • Member
  • Member
  • Love Them Kaws!
650ed wrote: What exactly is the engine's full serial number? Ed
KZT00DE001198
The Kaw List:
WTB: Z1-R engine or cases, KZT00DExxxxxx 25 Jan 2019 15:25 #797510
  • 79MKII
  • Member
  • Member
  • Love Them Kaws!
I'm not sure where the engine is from but it was in the bike when I first bought it 15 years ago. I checked to make sure it was a "D" serial number but didn't even know then that the numbers should have been closer.
The Kaw List:
WTB: Z1-R engine or cases, KZT00DExxxxxx 25 Jan 2019 16:18 #797513
  • Member
  • Member
Your engine number is correct for the 1978 Z1R so it may be the original engine even though there's a spread to the numbers. Take a look at the link below. Notice it shows for the 1978 Z1R:
1978 Z1000-D1 Z1R FRAME NUMBER: KZT00D-000001 >ENGINE NUMBER: KZT00DE-000001
Then for the 1979 Z1R it shows:
1979 Z1000-D2 Z1R FRAME NUMBER: KZT00D-017501 > ENGINE NUMBER: KZT00DE-017501
So given that info, your engine number is correct for the 1978 Z1R. I know that for most KZ bikes the engine numbers and frame numbers very quickly varied, and some varied quite a bit. Ed
www.z-power.co.uk/z1-r-z1000d
Last edit: by 650ed.
WTB: Z1-R engine or cases, KZT00DExxxxxx 25 Jan 2019 20:22 #797530
  • 79MKII
  • Member
  • Member
  • Love Them Kaws!
Yes, correct for a 78 Z1-R, but after looking a little more into the history, the Z1-R's have much closer numbers than the other 1000 models. In the Z1-R collector world, this is not a numbers matching engine. I'm hoping I can eventually find a set close to my frame number to have on hand.
The Kaw List:
WTB: Z1-R engine or cases, KZT00DExxxxxx 02 Feb 2019 14:41 #798078
  • Dragbike_Mike
  • Dragbike_Mike's Avatar
  • Member
  • Member
  • Thank you received: 16
79MkII - I still have two sets of "spare" KZ cases from back in my drag racing days. Turns out one of them is from a Z1-R (unbeknownst to me until now). Took a pic of the serial number - KZT00DE018363. It's probably even farther off than the one that you have now. I started stripping the black epoxy finish off (not knowing what I had, unfortunately) way back and remember what a PITA it was. Also, I'm pretty certain that I still have the crank from this motor. I recall that it was a bit of an "oddball". I thought that this was just a typical MkII motor, but the crank was not a standard MkII. Can't recall what the differences were. I'll have to look through the shelves and dig it out and give it a look.
And, I believe also that the reinforcing ribs on the front of the cases are also different than the MkII. At the time I thought that this was some kind of transitional motor that was supposed to bridge the gap from the early Z1/KZ to the MkII. If only I knew at the time....
Good luck with your search.
Mike
Presently - 1980 KZ1000B4 LTD w/mild ported head, 1015cc Wiseco, Falicon Supercrank, R&D undercut trans, +2" swingarm
WTB: Z1-R engine or cases, KZT00DExxxxxx 02 Feb 2019 19:40 #798088
  • 79MKII
  • Member
  • Member
  • Love Them Kaws!
Yep, those are Z1-R cases. Probably worth some decent money if you ever decide to sell them. According to zedder, they are from the 1980 Z1-R.
Year & Model '80 KZ1000-D3:Z1R
Color(s) Ebony
Frame No. Range KZTOOD-017801 - 021109
Engine No. Range KZTOODE017616 - 021069
Engine No. Location RH top crankcase, below carburetor
Cylinder Mark 1.015L
Cylinder Mark Location Front RH corner
Engine Type 4-stroke, 4-cylinder, DOHC, Air cooled
Bore X Stroke 70.0 X 66.0 mm
Compression Ratio 8.7:1
Maximum HP 94 at 8000 rpm
Maximum Torque 9.2 kg-m at 6500 rpm
The Kaw List:
WTB: Z1-R engine or cases, KZT00DExxxxxx 04 Feb 2019 05:52 #798156
  • Dragbike_Mike
  • Member
  • Member
Thanks for that info 79MKII - greatly appreciate it! And, yeah, those cases will be going up for sale, along with a few other items, a little later this year once I find some spare time. Would be nice if they went to a good home.
I see that there's a set of Z1-R cases on eBay right now. S/N KZT00DE001875 for $400 (plus $110 shipping - ouch!). Looking at the pics, it appears as though the main bearing cap for the crank has been milled flat for an APE reinforcing plate - could be a good thing, or not. Makes one wonder about the history of the motor. Maybe this serial number is closer to what you're looking for?
Thanks again.
Mike
WTB: Z1-R engine or cases, KZT00DExxxxxx 04 Feb 2019 06:20 #798159
  • 79MKII
  • Member
  • Member
  • Love Them Kaws!
Yeah, I think those cases have been down the drag strip a few times. The numbers are closer, but not close enough. Thanks for the heads up though.
The Kaw List:
  • Page:
  • 1
