  • Page:
  • 1
Very Early Z1 Petcock 17 May 2023 07:10 #884797
  • Moose1800
  • Moose1800's Avatar Topic Author
  • Thank you received: 210
Do we have any Z1 purist here that would like to make me a reasonable offer on this petcock before I put it on evilbay ?
I think this came from a very low vin# 74 Z1 I've had for many years, it is missing the screens. I noticed oink johnson just sold one for over $100.
Last edit: by Moose1800.
Very Early Z1 Petcock 17 May 2023 13:51 #884812
  • Buzz Nichols
  • Buzz Nichols's Avatar
  • Thank you received: 89
Yeah, but Oink Johnson's was a "drag bike part"
1978 KZ1000 LTD
The following user(s) said Thank You: slmjim+Z1BEBE, Nessism, sf4t7
Very Early Z1 Petcock 17 May 2023 18:22 #884819
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 957
The Z1's were black.  I've never seen a black one on a Z1A, but I would imagine they used up old stock before going to the grey ones.
Very Early Z1 Petcock 18 May 2023 04:54 #884831
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 509
We have two early black petcocks on the shelf that both leak. The rubber sleeves that serve as seals on the rotary valve need to be replaced.   They've been rumors over the years that some third party replacements were made, but we've never been able to track any down.
Mama Kaw modified the black petcocks with an O-ring on the rotary valve during production.  There's a service bulletin on it but can't look it up right now.  The rebuild kits we've seen for the black petcocks include it, but never the needed sleeve. It seems to be made of unobtaniium.
Our late '73 manufacure '74 Z1-A that slmjim bought new came with a late black petcock; it's one of the leakers on the shelf. When it began leaking many yeats later it was replaced with a later KZ900(?) or early KZ1000(?) dual output petcock that has the nylon cone valve.   We've never seen one of those leak.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Very Early Z1 Petcock 18 May 2023 07:50 #884837
  • Moose1800
Good Ridin'
slmjim & Z1BEBE
I have one of those on the bench right now, bought a rebuild kit for it and while it doesn't leak externally it doesn't shut off completely and fills the carbs. That tells me it's leaking past the nylon cone.
This petcock came from a 74 Z1A with a vin# of  Z1F- 20024 our friend Wheelhop bought the frame last year.
Very Early Z1 Petcock 18 May 2023 07:57 #884839
  • krazee1
  • krazee1's Avatar
  • Thank you received: 181
The petcock on my Z1A, which has a build date of March 1974, had the natural finish and also the leaky black inner sleeve. I just replaced it with a Tiawan manufactured petcock from Z1 Enterprises, so far so good.
GLWTS, by the way!
Mike
1974 Z1A (disassembled)
1976 KZ900B LTD (SOLD!) it's in GOOD Hands!
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
The following user(s) said Thank You: Moose1800
Very Early Z1 Petcock 09 Jun 2023 20:50 #885826
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 104
My late 74 Z1A petcock has the nylon cone, natural finish, and outlets 90 deg apart.  Just cleaned it, "lapped" the cone with a little toothpaste, and replaced the o rings and seals.  Got my fingers crossed, but it hasn't leaked in the past.
Scotty
1974 Z1A
1015 kit
welded Z1 crank
Andrews 1X Cams
  • Page:
  • 1
