  • Page:
  • 1
TOPIC: 38mm Mikuni Flat Slides
38mm Mikuni Flat Slides 15 Nov 2018 22:14 #793837
  • bluezbike
  • bluezbike's Avatar Topic Author
  • Thank you received: 104
Beautiful condition 38mm flat slides. They have been ultrasonically cleaned, have 130 main jets. I was looking froward to using them but they are too big for my application. $525.00
Let me know if you want any additional pics.
79 KZ 1000 LTD
38mm Mikuni Flat Slides 23 Nov 2018 18:47 #794155
  • jeffz
  • jeffz's Avatar
  • Member
  • Member
  • Thank you received: 13
What bike were they fitted to?
38mm Mikuni Flat Slides 23 Nov 2018 21:41 #794160
  • bluezbike
I had bought them for a project but they are too big for the application I had in mind. I believe the person I had purchased them from had them on a big Kawi motor.
79 KZ 1000 LTD
Last edit: by bluezbike.
38mm Mikuni Flat Slides 24 Nov 2018 13:18 #794180
  • jeffz
  • jeffz's Avatar
  • Member
  • Member
I'm interested, but letting a "guru" check my BS 34s before I give up on them.
The spacing between the carbs is different for diff. applications, so I'd want to be sure yours match what I have. My drawing shows the spacing for my 77 KZ1000 D.
Mikuni says the spigots on TM33-8012 flat slides are 40mm and the bell mouths are 50mm, is that what you have?
Thanks and good luck selling, your carbs look really clean.
38mm Mikuni Flat Slides 24 Nov 2018 21:00 #794187
  • bluezbike
TM33-8012 is a 33 mm single flat-slide carb so not to be confused with the 38 mm. set of four I have RS38-D19-K.
Outer diameter of the inlet/spigot side is 42 mm. and outer diameter of the exit (bellmouth) side is 55 mm. (your 34 mm do have an inlet dia. of 40 mm. and exit of 50 mm.)
The center-line spacing is 77-93-77 mm. which is specific to KZ 1000 carbs. as shown on the Mikuni website. This corresponds to the measurements you posted except the outermost one because 38's are that much wider than 34's.
79 KZ 1000 LTD
The following user(s) said Thank You: jeffz
38mm Mikuni Flat Slides 28 Dec 2018 23:24 #795857
  • bluezbike
Bump....someone give me a decent offer....need to sell these so I can get the ones I need, thanks for looking
79 KZ 1000 LTD
38mm Mikuni Flat Slides 17 Feb 2019 11:58 #798817
  • marcumc
  • marcumc's Avatar
  • Member
  • Member
  • Thank you received: 0
Do you still have the 38 mm your trying to get rid of?
38mm Mikuni Flat Slides 24 Feb 2019 03:28 #799130
  • bluezbike
Yes I do, cannot do anything til I am back from a trip abroad. I will be back on 5th March.
79 KZ 1000 LTD
38mm Mikuni Flat Slides 04 Mar 2019 14:01 #799704
  • Ed_in_Miami
  • Ed_in_Miami's Avatar
  • Member
  • Member
  • Thank you received: 47
God this is so tempting... my original carbs are giving me hell.....
This is my build:
kzrider.com/forum/11-projects/600312-ano...rtment-build?start=0
There are many more like it, but this one is mine... news to come!
38mm Mikuni Flat Slides 04 Mar 2019 20:49 #799741
  • bluezbike
Let me know if you have any questions on them, they are still here looking for the right home.
Many thanks.
79 KZ 1000 LTD
  • Page:
  • 1
