Tire rollers? Do they work?
  • Kawidave
  • Kawidave's Avatar Topic Author
26 Aug 2019 07:41 - 26 Aug 2019 07:43
#809872
Without a centerstand on my LTD I am interested in one of these to make rear wheel cleaning easier. This just happens to be HF's version. Comments? www.harborfreight.com/motorcycle-wheel-c...cEAQYASABEgK4QfD_BwE
Last edit: 26 Aug 2019 07:43 by Kawidave.
  • loudhvx
  • loudhvx's Avatar
Re: Tire rollers? Do they work?
26 Aug 2019 08:42 - 26 Aug 2019 08:44
#809873
Isnt that for a car? With the bike on the side stand, the tire will want roll off center and roll over the edge. Sounds like a mishap waiting to mishappen. :) I think a swingarm stand would be better.
Last edit: 26 Aug 2019 08:44 by loudhvx.
  • M_a_t_t
  • M_a_t_t's Avatar
26 Aug 2019 08:57
#809876
My brother got one for his bike and loudhvx is right. When you spin the wheel and it will start to move to one side of the roller. I think trying to get a centerstand fit is worth the effort.
You might look into a rear axle stand. I've only used one once on my brothers bike and it was quite awhile ago. Something like this, not a spool stand.
www.discountramps.com/rear-motorcycle-pa...cFai0WIaAthKEALw_wcB
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
  • Kawidave
26 Aug 2019 09:28 - 26 Aug 2019 10:23
#809879
I thought the tire might move sideways when turning, that's why I asked. A swingarm stand wont work with the oem LTD exhaust. It is to far back and to low. And when the stand pivots the angle of the stand will/hits the exhaust. I tried. I have one similar to what Matt linked.
Last edit: 26 Aug 2019 10:23 by Kawidave.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
26 Aug 2019 11:38 - 26 Aug 2019 11:43
#809884
I bought this lifter for a quick tire cleaning and chain Service, you can lift the front and rear or both with some wood supported under the Frame/engine.
Lift 1100lbs. Price is 35 - 45 Euro incl. shipping in Germany
www.manomano.de/p/motorradheber-motoradh...r-hebebuehne-6242291
www.amazon.de/Motorradhebeb%C3%BChne-Mot...500-kg/dp/B005JD5QZM
Last edit: 26 Aug 2019 11:43 by Scirocco.
  • Kawidave
26 Aug 2019 12:01
#809885
Don't want a lift. I already have one for my HD RoadGlide that I don't use.
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
27 Aug 2019 18:42
#809969
I have used that Harbor Freight roller extensively. It works ok, you just have to be careful. Find a block of wood for the sidestand so the extra height doesn't cause the bike to lean over further. Also, you can put the roller at a slightly different angle to the wheel so that the tendency to move sideways is counteracted. Obviously, you are not trying to turn the wheel with the engine running in 5th gear at 7500rpm, just turn the wheel slowly by hand with the engine off in neutral and stop and re-adjust if things start to go wrong. Simple as that.
The following user(s) said Thank You: Kawidave
  • 2strokerider
  • 2strokerider's Avatar
28 Aug 2019 11:12
#809992
I use a Pitbull rear swingarm stand for my RZ500. Works great.
proxy.duckduckgo.com/iu/?u=http%3A%2F%2F..._4228%2Bcopy.JPG&f=1
The following user(s) said Thank You: Barry1
  • Kawidave
30 Aug 2019 05:54
#810091
Like I said above, a swingarm stand won't work with the LTD's oem low and farther back exhaust.
  • Kawidave
31 Aug 2019 07:29
#810137
Kawidave wrote: Without a centerstand on my LTD I am interested in one of these to make rear wheel cleaning easier. This just happens to be HF's version. Comments? www.harborfreight.com/motorcycle-wheel-c...cEAQYASABEgK4QfD_BwE
Had a coupon for this @ $17.99 so I decided to give it a try this morning. So far I am satisfied with it. A block under the stand helps.
  • kevski
  • kevski's Avatar
03 Sep 2019 05:40
#810269
Scirocco wrote: I bought this lifter for a quick tire cleaning and chain Service, you can lift the front and rear or both with some wood supported under the Frame/engine.
I got one of these and use 2 large eye bolts in it and line them up with the main stand eyes and put two pins through.
The following user(s) said Thank You: Robb2018
  • Rick H.
  • Rick H.'s Avatar
08 Oct 2019 05:22
#812053
The manomano website has some interesting things on it. Wish it was in English so I could read what the stuff was for.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
