Torque wrench
  • Fox
  • Fox's Avatar Topic Author
Torque wrench
01 May 2017 06:15
#760875
Hello,
Just buy a new decent torque wrench and will start to work with it this afternoon...
But In the manual i have spec in kg-m and in-lbs
My torque wrench is in : NM or LB-IN
Example:
Clutch spring bolts at 0.9 - 1.1 KG-M or 78 - 95 IN-LBS
- Is in-lbs same has lb-in ?
- What do you use for unit to work generally?
Thank you
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
Re: Torque wrench
01 May 2017 06:23
#760877
Yes. But be sure never to confuse inch pounds with FOOT pounds.
What model bike are you working on, and which manual are you using? Ed
The following user(s) said Thank You: Fox
  • jdvorchak
  • jdvorchak's Avatar
Re: Torque wrench
01 May 2017 06:23 - 01 May 2017 06:30
#760878
I have a free torque app for my iPhone that does the conversion.
also use google EG: 1.1 kg-m to LB-IN will result in the correct numbers
But you're talking about such low numbers I would really doubt the accuracy of a FT/LB wrench. I have a 1/4 inch torque wrench that I use for little numbers like that.
but in your case just using simple math you can take the conversion of inch lbs to foot lbs by dividing inch pounds by 12 results in ft lbs. in your case that is about 8 ft lbs. Most ft lb torque wrenches start at 10 ft lbs
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
Last edit: 01 May 2017 06:30 by jdvorchak.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: Torque wrench
01 May 2017 06:31
#760879
Hi Fox,
In-lb and lb-in are interchangeable for our purposes.
We generally work in the SAE scales of in-lb and ft-lb.
Google "torque conversion chart" to convert one to the other.
You may sometimes see a torque spec stated in Newton/meters (Nm). Older assemblies seldom use the Nm spec.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
The following user(s) said Thank You: GPz550D1, Fox
  • KZB2 650
  • KZB2 650's Avatar
Re: Torque wrench
01 May 2017 06:33
#760880
While others may disagree I'd stay on the lower end of what they recommend too....half way max.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
The following user(s) said Thank You: GPz550D1, Nessism, Fox
  • Fox
Re: Torque wrench
01 May 2017 06:35
#760881
Hello
I use the kz1000 Motorcycle Service Manual (1976-1979) for a kz1000 ltd 1978 B2
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • jdvorchak
Re: Torque wrench
01 May 2017 06:36
#760882
When they were on sale I bought myself a 3/8 and 1/4 torque wrenches at Harbor Freight for about $10 each. Yes I have tested them both with math and against a "beam" type torque wrench and they are spot on.
John
83 KZ550M1
83 KZ1100LTD
Also own:
The following user(s) said Thank You: GPz550D1, KZB2 650
  • Fox
Re: Torque wrench
01 May 2017 06:47
#760884
And i don't understand why they put ft-lbs on the top of the table and all units are in-lbs inside the table ....
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • martin_csr
  • martin_csr's Avatar
Re: Torque wrench
01 May 2017 06:56 - 01 May 2017 06:58
#760887
Torque wrenches come in various sizes, and the size & amount of force is typically dependent upon the size of the bolt &/or the application.
It's best to have at least 2 torque wrenches. A big one in ft-lbs & a small one in IN-lbs.
When the specified torque is in INCH-lbs or for small fasteners which usually require only a small amount of force, a big torque wrench would be the wrong tool & you could snap off a bolt head or stud. Examples would be the exhaust holder nuts or cam cap bolts.
If a torque isn't specified for a particular bolt, Kawasaki manuals typically have a general bolt tightening table.
Last edit: 01 May 2017 06:58 by martin_csr.
The following user(s) said Thank You: Nessism, Fox
  • Fox
Re: Torque wrench
01 May 2017 06:57
#760888
Is it an error on the table title?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • martin_csr
Re: Torque wrench
01 May 2017 06:58 - 01 May 2017 07:31
#760889
No, it's for simplicity. Kawasaki service manuals assume the user has already obtained a certain level of training & competence.
When a Kaw mechanic sees in-lbs, he'll know to grab the small torque wrench.
(or he may do it by feel using a regular wrench without over-tightening the bolt).
Last edit: 01 May 2017 07:31 by martin_csr.
Re: Torque wrench
01 May 2017 07:02
#760890
KZB2 650 wrote: While others may disagree I'd stay on the lower end of what they recommend too....half way max.
I certainly agree. Stay on the low end of the range. Ed
The following user(s) said Thank You: KZB2 650, Nessism, Fox
