Lifting engine out with hoist by intake
  • bluej58
  • bluej58's Avatar
Re: Lifting engine out with hoist by intake
23 Oct 2016 04:53 - 23 Oct 2016 04:56
#745997
This is how I do it.
www.kzrider.com/forum/2-engine/489872-ho...ved-my-engine#489872
I have refined my method over the years by removing the oil plug and adding protection for the frame, but it works real good for doing it by your self.
78 KZ1000 A2A
Last edit: 23 Oct 2016 04:56 by bluej58.
The following user(s) said Thank You: loudhvx, BruceKoukalaka
  • rstnick
  • rstnick's Avatar Topic Author
  • Premium Member
  • Premium Member
23 Oct 2016 06:38
#746005
All great ideas guys.
But where are these lift threads using a hoist and bracket off the intake?
I'm sure more have seen these posts.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • KZB2 650
  • KZB2 650's Avatar
23 Oct 2016 07:41
#746007
That's the way I did it the first time Blue J and it went in good..... not sure why I'm so worried about it this time.... maybe will use a combo of both ideas.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • rrsmsw9999
  • rrsmsw9999's Avatar
26 Oct 2016 07:55
#746252
The K&L metric engine stand is the bomb for the money. No horsing the motor around on the ground. Worth every penny. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • KZB2 650
  • KZB2 650's Avatar
27 Oct 2016 07:34
#746298
I was really close to buying the metric stand but since I wasn't going to split the cases and I was going over budget I picked up a engine stand on sale and made up some brackets with threaded rods like shown on here some place...... worked great for spinning it around a half a dozen times to spray it out from the top and bottom getting it pretty much spotless inside.
1978 KZ650 b-2
  • rstnick
  • Premium Member
  • Premium Member
Re: Where is the thread - Lifting engine by intake
28 Oct 2016 12:51 - 28 Oct 2016 12:52
#746386
Anyone else recall where these thread about lifting an engine by the intake, with a hoist, are?
B)
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 28 Oct 2016 12:52 by rstnick.
  • rstnick
  • Premium Member
  • Premium Member
05 Dec 2016 17:57 - 05 Dec 2016 18:49
#749580
Well I've found some info and pictures of the tool to lift an engine out.
I thought it was here I had seen it, but it seems not.
Sorry about the confusion.
Here are the pictures, and some info;
John, "This is an engine swap rig I fabbed this after one that an old time Kawi mechanic had made. I have yet to use it, but it worked slick when he did. Put a clevis in the top hole on the short piece, bolt the long section to the motor and use an engine hoist."
[IMG
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 05 Dec 2016 18:49 by rstnick.
  • rstnick
  • Premium Member
  • Premium Member
05 Dec 2016 17:58
#749581
And AJ; "Built the hanger and used it today. Works like a dream. Put it up in there air and moved it out into the rocks so I could finish cleaning before painting. I could sit on a chair, twist it, didn't have to wrestle it around. Love it. I'll build one for each engine family I work on."
[IMG
[IMG
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
The following user(s) said Thank You: bluej58, BruceKoukalaka
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
05 Dec 2016 18:46
#749588
Cant argue with that !!!
Post some dimensions if you can some time
Dave B) B) B)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
06 Dec 2016 08:44
#749653
pretty slick.
