Harbor freight lift, finally.
- Timbox
Motorcycle lift Harbor Freight coupon
04 Dec 2015 03:27
Just picked one of these up for the different bike projects that I seem to get into. Getting to the age that working on the floor is no longer what I like to do. Here is the coupon from Harbor Freight, I think it is a good deal.
www.harborfreight.com/1000-lb-Capacity-M...=mEmail_s1035_c4915c
Just make sure you have a trailer or truck and a way to get the lift loaded and unloaded. Comes in a small coffin like box.
Will be adding some pics of the JB weld patch of that cover. If that does not work then I will look into MIG/TIG or other patch.
Long time shade tree wrencher
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
- MadShad
Re: Harbor freight lift, finally.
11 Mar 2016 19:16
So I finally spent a little cash, not the best but for how often I'll use it, it will be fine.
Went on sale this weekend. Of course this is just AFTER I've got several things sorted on the bikes in prep for better weather. :blink:
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
- Stev-o
11 Mar 2016 19:22
Hope you bought the extended warranty, mine stopped lifting after 3 months.
'75 Z1 '74 H1 '74 H2 basket case ..... plus plus plus...
- MadShad
11 Mar 2016 19:28
I'd say figuring out a way to fix it would be easier than dealing with harbor freight staff on a warranty, lol.
At any rate hope mine lasts a little longer, if it doesn't, I'll fix it.
Sorry for your crappy luck.
- GPzEric
11 Mar 2016 19:55
I've had mine for a few years - and I love it.
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
- StreetfighterKz
11 Mar 2016 20:26
I love mine. I swapped out the "leaves something to be desired" wheel clamp with one of HF locking wheel chock. Be sure to check the hydraulic oil on the ram. Mine was almost a pint low. Another mod I made was moving the U-clamps to the position about 3' fron the front. I then took the ratchet end of a tie down strap and cut the hook off and fed the U-clamp through where the hook attached. I can then use the ratchet straps without having to balance the bike as well as trying to keep both hooks of the strap hooked.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: MadShad
- MadShad
11 Mar 2016 20:42StreetfighterKz wrote: I love mine. I swapped out the "leaves something to be desired" wheel clamp with one of HF locking wheel chock. Be sure to check the hydraulic oil on the ram. Mine was almost a pint low. Another mod I made was moving the U-clamps to the position about 3' fron the front. I then took the ratchet end of a tie down strap and cut the hook off and fed the U-clamp through where the hook attached. I can then use the ratchet straps without having to balance the bike as well as trying to keep both hooks of the strap hooked.
Later, Doug
My little cb100 cafe was a breeze to load up, it's tiny.
I got the 550 up there and had to dance around quite a bit before I got it on the centerstand, not good.
I love the strap idea, and I've seen one with that wheel chock. Both seem like worthwhile upgrades.
- jakedude
15 Mar 2016 17:28 - 15 Mar 2016 18:33
I love my HF lift. I did make some modifications to it however. First I added a small peninsula to the side so I could easily put the side stand down so I could get off the bike and then put it on the center stand. This is particularly helpful when putting my GL1500 goldwing on the stand. The lift is rated to 1000 lbs and a GL1500 weighs 900 lbs.
Then I added a peninsula on the front so I could ride the bike further up on the stand to make sure the center stand wasn't too close to the trap door used for rear tire removal. The photos show my GL1500 with the rear tire removed.
Finally I cut the back bar away from the tire removal trap door from the stand and replaced what I removed metal with bolt on angle steel. That makes rear tire removal much easier.
I haven't had a problem with the lift in the three years I have owned it. I have had my kz1000-P7, DL650, and my GL1500 on the lift many times.
Attachment IMG_0406.JPG not found
Attachment IMG_0411.JPG not found
Attachment IMG_0408.JPG not found
Attachment jd1.JPG not found
Attachment jd2.JPG not found
Attachment jd3.JPG not found
Nothing lasts, nothing is finished, and nothing is perfect.
Last edit: 15 Mar 2016 18:33 by Patton.
- Bowman
15 Mar 2016 17:34
Looks pretty sweet but how do you keep all that stuff on the ceiling?
Honda 55 Trail don't ask me what year, 65? (sold)
79 Yamaha XS400 (sold)
76 KZ750B Twin (project)
72 Honda CT70 (project)
- jakedude
15 Mar 2016 17:41Bowman wrote: Looks pretty sweet but how do you keep all that stuff on the ceiling?
Yeah, I tried to fix that twice. They show right side up on my computer but not when posted. I even tried to rotate them upside down on my computer and they still post upside down. Maybe someone can tell me how to post them right side up.
- missionkz
15 Mar 2016 17:54The same damn thing happens to me 75% of the time I attach a photo!! Maddening!jakedude wrote:Bowman wrote: Looks pretty sweet but how do you keep all that stuff on the ceiling?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- Bowman
15 Mar 2016 18:09
Yeah, I was just being a smartass but you knew that. Wish I had the garage room and $ to get one of them lifts
