Harbor freight glass beading cabinet
- wireman
Re: Harbor freight glass beading cabinet
23 Mar 2013 00:21
Only problem with the pl400 would be if I needed to take it apart to modify things
- LarryC
23 Mar 2013 09:33 - 23 Mar 2013 09:36
The silicone between the joints is what's going to stop it from leaking. You won't get good results if you assemble it and then caulk it. It needs the sealer in between the joints while it's going together.
Good Siliconek like the GE clear is excellent in damping the force of a glass bead that's propelled by compressed air. Don't believe me? ....Coat something porous with silicone, let it dry completely...then put it in the cabinet and see how long it takes to blast it off :S
That cabinet is about 6" too small vertically, depth & horizontally to comfortably blast inline 4 cylinder heads & cases in. It works but it's awkward.
Larry C.
Last edit: 23 Mar 2013 09:36 by LarryC.
- Powerstroke_fan
23 Mar 2013 09:50 - 23 Mar 2013 09:53
Ya it is kinda awkard blasting bigger items. I used some spray foam on the bottom of mine and its worked great the only places is leaks is out the vents and round window and thru the holes in the rotted gloves :lol: So where does everyone get there replacement gloves and screens?
1977 KZ 1000 work in progress
Last edit: 23 Mar 2013 09:53 by Powerstroke_fan.
- LarryC
23 Mar 2013 18:27
ebay "blasting cabinet gloves"
Larry C.
- steell
- ThatGPzGuy
25 Mar 2013 20:57rstar45 wrote: Sure Jim,
Block of wood to help glue / hold an input directed at the side of the bucket sets the air spinning.
Made a cone to fit just above the inlet.
And a couple air filters on the lid.
Sure glad you asked... I really need to clean that sucker. :lol:
That's pretty cool and it looks like it works too
Thanks!
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- wireman
25 Mar 2013 21:52
I got it all put together the other day,just haven't had time to try it out yet. :sick:
all this crazy ass cold weather has left me loaded down with extra furnace calls I really didn't want. :laugh:
- Kidkawie
- I bleed premix
26 Mar 2013 10:30
What about Gorilla tape over the seams? Only asking because I have some.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Kidkawie
- I bleed premix
12 Apr 2013 10:06 - 12 Apr 2013 10:07
Any updates? I'm about to pull the trigger on it.
1975 Z1 900
2004 KX125
2004 KX125
Last edit: 12 Apr 2013 10:07 by Kidkawie.
- steell
12 Apr 2013 13:42
I think Cycle and Motorcyclist magazine have Harbor Freight ads with a 25% off coupon.
- wireman
12 Apr 2013 13:56Yeah Ive used it quite a bit,I need to seal around the door like Larry was saying .Kidkawie wrote: Any updates? I'm about to pull the trigger on it.
Havent had time to get a better light fixture or make an adaptor for shop vac yet(busy doing plumbing/electrical bids :sick: )
But overall it definitely gets the job done ,For the price I cant complain :laugh:
- Kidkawie
- I bleed premix
12 Apr 2013 15:26steell wrote: I think Cycle and Motorcyclist magazine have Harbor Freight ads with a 25% off coupon.
I found one online for 20%.
1975 Z1 900
2004 KX125
2004 KX125
