Have U got a homemade parts washer?
- Nelson
22 Apr 2011 02:37
how did you make it? What components did you use? it's such a simple device it seems like a great thing to make yourself.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- purls
Re: Have U got a homemade parts washer?
22 Apr 2011 03:29
Not homemade, but I've had success using a friend's ultrasonic cleaner. Cleaned my petcock right up, along with a few other small things. You couldn't use it for anything big, but a used one isn't hard to find. The one I'm using is a spare, and he uses them to clean medical grade stuff. Cleans tons of stuff really well. No solvents required, but you can use them.
luck,
purls
luck,
purls
1983 KZ750 Spectre
1978 KZ650B2A
1978 KZ650B2A
- Proxy
- 80% Human 20% Nuts/Bolts
22 Apr 2011 09:12
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- wireman
22 Apr 2011 09:18
a hose run from a fish tank pump run to the bottem of a plastic tub like that helps keep things stirred up,cleans better
- Proxy
22 Apr 2011 10:04
22 Apr 2011 10:15:laugh: :laugh: :laugh:
Attaching dirty part to the propeller also seems to help.
- Kidkawie
- I bleed premix
22 Apr 2011 10:19
Before i bought my parts washer I used a 5 gallon bucket with a coupla tins of mineral spirits in it.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Motor Head
22 Apr 2011 10:21 - 22 Apr 2011 10:25
A 55 or 30 gallon drum, depending on size/ space, cut in half length wise. With a smooth straight cut, you can add some angle Iron for a good fitting lid area, and strength. Hinge the back so you have your lid, put it on a stand, preferably metal, add a pump if you want, also the small bung down for draining later. And I still use a mix of Diesel and gas, 7:1 seems like a good ratio, so ventilation is a must.
Last edit: 22 Apr 2011 10:25 by Motor Head.
- roy-b-boy-b
22 Apr 2011 10:38
You could probably buy one as cheap as you could build one. I think mine was under 50 bucks.
22 Apr 2011 12:11
like roy said.
www.harborfreight.com/6-1-2-half-gallon-parts-washer-96952.html
hard to beat that for less than $50.00 bucks ready to fill up and plug in .
hth,
hth,
- dshelly
22 Apr 2011 12:19
For large parts, steel or cast iron only! Use a 55 gal. steel drum cut off. Raise drum up with a couple cinder blocks. Add a heat source underneath ( preferrably outside) add water and a can of crystal drain cleaner. Let parts sit and agitate every so often. Takes off grease , paint and any other stickey residue. Just don't stick your arm in there.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Nelson
22 Apr 2011 16:14
and whats that solvent called... you know the stuff that was standard in autoshops for years. I wanna say "stoddard solvent" does that sound right? where do I get it?
I'd like something that won't leave a residue so it's ready for painting engine parts.
