3 angles in one shot with neway cutters
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
Re: 3 angles in one shot with neway cutters
18 Sep 2010 09:59
#399613
Ahhh. Missed that part. Sweet.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • larrycavan
  • larrycavan's Avatar Topic Author
18 Sep 2010 16:33
#399711
Got an email from Ricardo. He's got my custom blades made already :) and sent me pics of the seats he cut with them. What a great guy ;)
  • Motor Head
  • Motor Head's Avatar
18 Sep 2010 16:40
#399712
Were the custom ones the same price, curiosity, and how did the ones you tried turn out?
You like the supplier i can tell, hows the tools working for ya. Hopefully all is good to be better with he custom angles!
  • larrycavan
18 Sep 2010 16:44
#399714
Here's a pic.
When I install larger valves, I sink them with a 30 to the installed height I want, then do the valve job. So I had a set made with 35/45/60 with the seat width I like.
Using a 75 on the bottom yields a nice 5 angle valve job.
While it's not nearly as fast as a blade cutter setup it is straight and the valves are seated before the engine is fired up.
After you cut your seats, drop the valve in and tap on it. If it clicks, it's not mated properly.
  • Motor Head
18 Sep 2010 16:46
#399715
What do you think compared to the "Stone" method?
  • larrycavan
18 Sep 2010 16:57
#399721
For the actual seating cut, a stone is awesome! I's pretty difficult using stones to cut multi angles on seats and have them all be the same from port to port.
What works well is to use the carbides for top and bottom cuts, then true up a stone and zing the 45 using a bounce spring.
People say stones are antiquated but they dam will spin a straight cut :laugh:
