Best Air Compressor for Garage Use?!?!?
  • z19OO
  • z19OO's Avatar
Re: Best Air Compressor for Garage Use?!?!?
24 Feb 2010 20:37
#349998
I just found a brand NEW Kobolt 26 gal. on CL. Came with a 50 piece tool kit too for $150. Its oil less but it sure beats the 2 gal pancake i've been using to fill car, atv & motorcycle tires. :S Its a little loud but for that price who cares........
1975 z1 900
1979 kz650b
  • badrhino
  • badrhino's Avatar Topic Author
25 Feb 2010 09:21
#350074
Well i seen pics of the unit. It is old and is rigged up for more gallons with an external tank. Looks kinda sloppy and it is a horizontal unit 22ov. I am looking for a 110V Stand-up unit. I think I wil just try a Harbor Freight one. Craigs List is readily available in these parts of Kansas so traveling to get something is out of the question.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • Galactica
  • Galactica's Avatar
25 Feb 2010 10:55
#350091
When looking for a compressor to use for soda blasting, aside from cfm, what pressure is required?
77KZ1000
76 KZ900
  • otakar
  • otakar's Avatar
25 Feb 2010 12:29
#350112
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • badrhino
25 Feb 2010 14:30
#350128
Yep, the red one is the one I'll probably get.
Franken Z!
  • thompsonmx100
  • thompsonmx100's Avatar
25 Feb 2010 14:53
#350133
I found my setup worked better at 90 psi. they all build enough pressure it just the cfm that you need to be concerned with.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • z19OO
  • z19OO's Avatar
25 Feb 2010 17:00
#350159
That looks like a good deal on the red one......
1975 z1 900
1979 kz650b
  • Galactica
26 Feb 2010 09:20
#350275
So for soda blasting, best to look for max cfm @ 90 psi.
77KZ1000
76 KZ900
  • jjdwoodman
  • jjdwoodman's Avatar
  • Live free, or die.
26 Feb 2010 14:58
#350302
You definitely want a large cfm for blasting, and a two stage pump would be a plus if you couldn't get your hands on a vane type pump. They're designed for continuous output.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • ssbenn11
  • ssbenn11's Avatar
22 Sep 2010 12:15 - 22 Sep 2010 12:16
#400901
I really like what I've got. Ingersoll Rand portable air compressor. They have more heavy duty ones too.
Check out the website IR Air Compressor
Last edit: 22 Sep 2010 12:16 by ssbenn11.
  • gcarson64
  • gcarson64's Avatar
22 Sep 2010 21:18
#401078
i just bought a craftsman 30 gallon vertical compressor about a week ago. it was 300 and works for medium duty use with the cut off tool. :)
1980 kz550 38,500 miles basket case ( soon to be a BOBBER )
1983 kz550 9,600 miles
1988 jeep grand wagoneer 144,500 miles 4 mpg
  • MFolks
  • MFolks's Avatar
22 Sep 2010 23:16
#401098
If you plan on plumbing the compressor in the garage/shop, avoid using the PVC pipe, if you do, it's potential bomb waiting to go off. Spend the money and get the thick walled copper pipe and the fittings. I've heard/read the PEX lines have been used for an air supply, but I don't know the pressure limits.
Black iron pipe has been used, but I don't like the rusting potential after a few years, besides, most black iron pipe is made in China and leaks big time unless you get a pipe tap and die and re-do the threads.
www.practicalmachinist.com/vb/general/co...distribution-208613/
www.practicalmachinist.com/vb/general/pex-air-line-192203/
