temp fuel source
- Silverado6x6
Re: temp fuel source
22 Jan 2010 05:06
When I was working on my Honda CX 500 I took some galvanized pipe bushings and made a reducer from a 8" piece of 2" pipe down to a 1/4" brass barb with a see through fuel filter, that was fine for that bike but now I need to make another that has two fuel outlets for the Z1B I'm working on, or I'll just make another of the same.
I would just hang this over the handlebar and it wouldn't give a lot of run time but it was easy to top off.
- mtkawboy
14 Mar 2010 15:57
Old snowblower tank for you northern guys is what I use with a shutoff valve & hoses set up for 1,2,3 or 4 cylinders
- 9am53
- homebrew, and some bbq
18 Mar 2010 07:03 - 18 Mar 2010 07:04
I am getting ansy and want to start up my bike, so I am going to let the paint on the tank cure and am going to try using the bottle from my lucas break in oil additive. I will rinse it out really well with some gas, and then stick the pointy spout into my fuel line, hopefully the little barbs hold in the fuel line!
Would I need to plug up the vaccum line on my BS34 carbs if I am using this temp fuel source?
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
Last edit: 18 Mar 2010 07:04 by 9am53.
18 Mar 2010 09:40
Yes, vacuum should be capped.
And fuel source should be vented.
- krazinite2003
17 Jun 2010 19:05
9am53 that is what i use for my temp fuel sorce but i found that it my leak where the hose conects to the pointy end of the bottle
i have two 1983 kz750 L3
- KZQ
- Administrator
17 Jun 2010 20:06 - 17 Jun 2010 20:07
Take one paint thinner can add a barbed hose fitting and a bit of solder.
This one's been feeding my projects for thirty years.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Last edit: 17 Jun 2010 20:07 by KZQ.
- larrycavan
19 Jun 2010 02:29
Old 2 stroke oil reservoir tanks work great for that as well. Mine hangs from the handlebars and "IT'S GENUINE KAWASAKI" so the carbs synch in more precisely :laugh:
- stonemaster
21 Jun 2010 18:48
someone needs to make one out of one of those Heineken mini kegs
