Preserving '79 SR Muffers
  • dbroten
  • dbroten's Avatar Topic Author
15 Dec 2006 18:13
#99885
Does anyone know of any shop that is able to remove the stock mufflers from my '79 650SR and then remove, replace, refresh, and/or repack the muffling material and then replate the chrome on the mufflers so I can preserve the stock mufflers? If you know of a shop anywhere in the lower 48 states I would be most appreciative. Thanks.
Darrell Broten
Eau Claire, Wis
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Preserving '79 SR Muffers
15 Dec 2006 19:18
#99898
I could be wrong but there should be no "packing" inside. It should be all mechanical baffles,never wear out other than rust. Any good chrome shop can replate them...
  • dbroten
17 Dec 2006 07:38
#100117
Bluemeanie:
Thanks for the info! Now "for the rest of the story." what do you mean by a "good chrome shop?" Do you know of any good chrome shops and where are they? Even if they are in California let me know. As long as we are dialoging, do you know of any good suspension shops? I am planning on modernizing the suspension on the '79 KZ 650 and would like to take the bike into such a shop and have them completely update the suspension. I would do so if I knew of such a place, or is such an update merely a matter of buying aftermarkets shocks and springs, installing them, and crossing my fingers? I am looking for a place that specializes in suspension. Thank you so much!
Darrell
Wisconsin
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
17 Dec 2006 08:03
#100120
Hey Mr. db,
You'll need more than a good chrome shop to get your exhaust system re chromed. Every shop that I've spoken to refuses to touch any pipe that may have carbon deposits hidden inside. The problem is that the carbon fouls the electrolyte, ruining it for the next project. I can only suggest that you do your best to polish em up. There are several manufacturers that are making replacement systems that are good knockoffs, though I believe only for the most popular bikes.
Good Luck
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • JMKZHI
  • JMKZHI's Avatar
Re: .
20 Dec 2006 07:50 - 03 Dec 2008 11:16
#100650
del
Last edit: 03 Dec 2008 11:16 by JMKZHI.
  • pumps
  • pumps's Avatar
20 Dec 2006 07:59
#100653
That is first time I have seen the stock SR criss cross pipe set for sale. They really don't look as good as mine it doesn't appear..unless they clean up well.Pretty pricey on the shipping too as you say JM. OUCH :pinch:
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
  • JMKZHI
  • JMKZHI's Avatar
Re: .
20 Dec 2006 08:09 - 03 Dec 2008 11:17
#100657
del
Last edit: 03 Dec 2008 11:17 by JMKZHI.
  • pumps
  • pumps's Avatar
20 Dec 2006 08:14
#100659
Mine are blued and the left muffler has some spots where battery acid took off the chrome but I can live with it for now. If I decide to spend money on exhaust it's going to be a 4-1 pipe. The ONLY thing I don't like about that is that it takes away the balanced look..I know it sounds kind of nit picky but I like the way it looks ..pipes on both sides.But I sure do like to hear that 4-1 sound!:woohoo:
1977 Yamaha XS650
2000 Kaw W650
  • JMKZHI
  • JMKZHI's Avatar
Re: .
20 Dec 2006 08:44 - 03 Dec 2008 11:18
#100666
del
Last edit: 03 Dec 2008 11:18 by JMKZHI.
  • dbroten
20 Dec 2006 18:20
#100802
Hey Guys,
Thanks for the inputs. From the sounds of it, I think I'll just look for a replacement set of mufflers and forget replating the stock mufflers. Instead, I'll concentrate on upgrading the suspension, which almost than anything else directly affects the day-to-day feel of the bike. Anyone know of a suspension shop? Thanks.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
20 Dec 2006 18:38 - 03 Dec 2008 11:19
#100809
del
Last edit: 03 Dec 2008 11:19 by JMKZHI.
  • pumps
  • pumps's Avatar
20 Dec 2006 20:51
#100842
You know i had asked about replacement mufflers before and someone pointed me to some in the JC Whitney catalog that were reasonable that they had bought and liked well enough.You might look there. If I remember it was
these.
JMK aren't those taller than stock? I was thinking mine are in the 12" range...
Post edited by: pumps, at: 2006/12/20 23:52
1977 Yamaha XS650
2000 Kaw W650
