Valve Clearances on Z900
- rammy
Re: Valve Clearances on Z900
05 Dec 2006 05:54
Yes you may experience some ticking.
I never like to see a valve in a KZ 900/1000 motor tighter than .004" lash, no matter what cam is in the bike.
.004IN with .006 Exh is a pretty good setup.
Ill agree with this setting 100%. I had set my 650 to these specs after changing the springs last year and have had NO problems or noise. You should run the exhaust about .002" looser than the intake because they will tighten up a bit after running.
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
- kzwolfsr
05 Dec 2006 06:09
To LARRYCAVAN I have a 650. I was just commenting on the difference in georges explanation for changing shims.
Original man of the Caribbean
- larrycavan
06 Dec 2006 00:14
10-4 on the 650.....thought it was a 900.
I'd still follow the same guidelines.
You might try doing a very careful carb synch and see if it helps the ticking situation.
