replacement sleeve fit...turn or bore...
  • Duck
  • Duck's Avatar Topic Author
  • e vica na i sau na ga
26 Nov 2006 14:07
#95100
Probably a question for Jay.
I glommed a old stock LA sleeve brand 'stock size' sleeve
for kz1100/gpz1100. Natch, the first thing I do is measure it.
Outside is perfect match to the old sleeve.
Inside is enough on the small side that it's gonna need more
than a hone. I can turn to within a thousandth or two of the
final piston clearance. If there's any risk of the thing
going out of round when it's installed, I'll put it in and
let the machine shop with the jig bore it.
So what say...turn or bore???
-Duck
Post edited by: Duck, at: 2006/11/26 17:08
  • wireman
  • wireman's Avatar
Re: replacement sleeve fit...turn or bore...
26 Nov 2006 15:17
#95117
im as ambitous(spell check)as anyone,but definately take it(sleeve in block) and the pistons to machine shop.;)
Post edited by: wireman, at: 2006/11/26 18:34
  • steell
  • steell's Avatar
26 Nov 2006 15:21
#95118
Bore the sleeve after it's installed in the block, otherwise you are wasting your time.
My $0.00002 anyway :)
  • Duck
26 Nov 2006 15:37
#95125
Think I'll take the old sleeve out and measure the hole. If it's
round, then I won't have to worry about the new sleeve changing
shape and can turn it. I already measured the outside of the new
sleeve and it's perfectly round.
Sound reasonable?
  • roystaylor
  • roystaylor's Avatar
26 Nov 2006 17:19
#95150
Yeah, go ahead, everyone sez install the sleevs into the block then machine it. So go ahead and turn it and install. Why bother posting the query? By the way, I agree with installing the liners, then machining
  • larrycavan
  • larrycavan's Avatar
26 Nov 2006 17:21
#95153
You definitely want the sleeve in the block when it's bored. The block to sleeve is about a .004" crush fit.
Do not expect the tollerance to be held if you bore the sleeve outside of the block and then install it.
  • APE Jay
  • APE Jay's Avatar
26 Nov 2006 18:09
#95174
Absolutly finish the bore after it is in the block.
Jay
  • Duck
26 Nov 2006 18:12
#95177
Why post the query?
Because I want to know if it's reasonable or not.
If I already knew, the block would be in the oven.
Sometimes things are done a certain way because it's entrenched
"good practice", Everyone does it this way is taken to mean that
'this way' is the only way that works. I know the one way works.
I'm curious about the other.
I'm glad you asked.
  • Duck
26 Nov 2006 18:20
#95180
Jay
Jay, Thanks.
I'm still curious. What happens that makes the other approach
to sizing (as opposed to finishing) unworkable?
-Duck
  • hwms
  • hwms's Avatar
27 Nov 2006 13:26
#95383
What happens when you put a kit (new pistons, sleeves, etc)
in a used case? Do you have to rebore ?
  • APE Jay
  • APE Jay's Avatar
27 Nov 2006 15:35
#95410
Duck wrote:
Jay
Jay, Thanks.
-Duck
It is a shrink ( interference fit) When the block cools down it is squeezing the sleeve, that can distort the bore. So put it in, let it cool, press it down when it has cooled, then finish the bore while it is being squeezed.
Jay
  • baldtires
  • baldtires's Avatar
28 Nov 2006 19:47
#95832
as a rank amature machinist,i say go for it
i want to know if it can be done
