77 KZ1000 1/4 times
- rattler
Re: 77 KZ1000 1/4 times
26 Nov 2006 19:15
modprod wrote:
as for pulling close to redline in fourth gear in the 1/8 is impossible for me. at the end of the 1/8 i am just hitting forth gear. could actualy stay in third but would be hitting the rev limiter at the finish light.
900cows wrote:Dragracing,your desire would be at the other end of the track.what ever the bike pulls to(your redline)HIGH GEAR-REDLINETHATS YOUR GEARING.
I agree with this. For the 1/4, gear to pull very close to redline in 5th. For the 1/8th, gear to pull close to redline in 4th. Of course this will limit top end and cause a higher "cruise" rpm but this will optimize your dragstrip ET potential.
- modprod
27 Nov 2006 09:26
rattler wrote:
[/quote]as for pulling close to redline in fourth gear in the 1/8 is impossible for me. at the end of the 1/8 i am just hitting forth gear. could actualy stay in third but would be hitting the rev limiter at the finish light.[/quote]
That's because you don't have it "geared correctly" for the "optimum" 1/8th ET. You'd probably have to go down a tooth on the front or up 2-3 on the rear or some combination of the 2 like maybe 1 down on the front and 1 up on the rear? I'm talking "optimum" here.
- rattler
27 Nov 2006 16:39
i am already runing 46/16 gears. i know i would benifit in the 1/8 if i drop the front to a 15 but i want to keep some of the top end for the highways.
you can always find extra horse power for sacrificing whats in the bank.
i think i am going to drop in some 420 cams and do some head work after the first of the year and see were i am at then.
- ZED
30 Nov 2006 18:29
KZR track day Jan 13th and 14th 2007 Moroso motor speedway South Florida. It actually is Bike weekend. Lanyard ignition cut off required, anyone GAME?
