Number on piston?
- cnyl
Number on piston?
14 Nov 2006 06:06
Hi guys. I just cleaned the pistons on my 80 Kz550. There is the number 50 marked on top of them. Does that mean it's bored 50 over? I noticed that a stock piston has no marking on it.
Thanks
Thanks
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
- Duck
- e vica na i sau na ga
Re: Number on piston?
14 Nov 2006 07:20
Most likely 0.50mm over. Not 50 thousandth of an inch over.
- CoreyClough
- GPz550 Addiction
14 Nov 2006 07:46
Factory offers two sized over stock, and I believe they are in mm.
'85 GPz550(ZX550-A2)
- cnyl
14 Nov 2006 13:36
Thanks guys. So when I buy new rings I need to get 2 over? (2 over = 0.50)
:huh:
:huh:
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
North Port, FL
Check out my band
- steell
14 Nov 2006 14:19
It seems like most KZ's use .5mm as the first oversize and 1mm as the second oversize. I don't think I have seen any .25mm oversize, so you would have 1st oversize pistons.
- cnyl
14 Nov 2006 18:34
Ummmmmm. :huh: Now i'm confused. It doesn't take much.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
North Port, FL
Check out my band
- steell
14 Nov 2006 19:30
Everyone is saying the same thing, .5mm=.50mm
I think you probably need the following part number (4 each):
13025-1010 RING-SET-PISTON-L
.50mm = .020"
Aaww crap!! I was editing my post and accidentally deleted all my references!!
Short version:
There is a seller on eBay that is selling a .50mm oversize piston for a KZ550. If you copy the part number he has listed and paste it in the "Part Number Search" block at Ron Ayers it will show you the part number that superceded that one, then go to Kawasaki.com and look up the part number for first oversize (L) pistons for your bike, and you will see that the part numbers match.
50 = .50mm = first oversize = I QUIT!!!
Can't believe I had to type all that twice. now my two typing fingers are all worn out :laugh: :laugh: :laugh:
Post edited by: steell, at: 2006/11/14 23:07
.50mm = .020"
Short version:
- rstnick
15 Nov 2006 06:24Aaww crap!! I was editing my post and accidentally deleted all my references!!
I hate when that happens!
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- 77KZ650
15 Nov 2006 06:32
kinda on topic questions: are the kaw OS pistons also made by ART (same as the stock ones)? and are they generally the same compression ratio?
Scott
Scott
07 MDP Rookie of the Year
- steell
15 Nov 2006 06:53
77KZ650 wrote:
The 750 twins and fours are, I don't have first hand knowledge on other models though.kinda on topic questions: are the kaw OS pistons also made by ART (same as the stock ones)? and are they generally the same compression ratio?
Scott
- wiredgeorge
15 Nov 2006 06:59
They are ART pistons for the OEM oversized for the 900/1000 I believe... also same compression ratio.
Post edited by: wiredgeorge, at: 2006/11/15 10:00
- cnyl
15 Nov 2006 07:02
Thanks steel. Let those fingers rest for a while..
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
North Port, FL
Check out my band
