Dead number three cylinder
- Duck
- e vica na i sau na ga
12 Nov 2006 15:16 #91468
by Duck
Replied by Duck on topic Dead number three cylinder
So what is wrong with number three on the other two sets of carbs?
- mark1122
- Keep twisting it
- Thank you received: 109
12 Nov 2006 20:35 #91560
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Dead number three cylinder
good point duck
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wiredgeorge
13 Nov 2006 07:37 #91644
by wiredgeorge
Replied by wiredgeorge on topic Dead number three cylinder
The brass spigot on the #3 carb connects to a passageway directly to the venturi. It is a vacuum port used for connecting to a vacuum actuated petcock. The fact that you tried other carbs and had the same problem sort of through the troubleshooting off track.
- KZone900
13 Nov 2006 13:19 #91723
by KZone900
Replied by KZone900 on topic Dead number three cylinder
There was more than one problem with this bike. The origional coils and wires were bad and it happened to effect no. 3 cylinder, the wire was broke at the coil for no 3 cylinder. Replaced the coils and did a valve job and replaced the guides and found weak valve springs for no 3 cylinder too. So you can see why I was at my wits end with this combination of problems. Why it all happened on that cylinder is beyond me. Thanks for the help.
