Where can I get brushes for a starter?
  • Sweet Back
  • Sweet Back's Avatar Topic Author
Re: Brushes for starter? Where?
05 Jan 2006 08:03
#16103
My only concern about going with something like that off ebay is that its older than my bike and it may be 2 months before I have to rip into the bike again, if it works initially.
I did find this place, www.stockers.com/PSkawastreet.htm on first internet search. If you click on the red numbers to the left of each bike it has a starter, or rebuild parts, brushes and so on. I think this may be my solution.
1996 KZ1000P
  • wiredgeorge
  • wiredgeorge's Avatar
05 Jan 2006 11:32
#16117
Rip into your bike? It takes about 10 minutes to replace a starter. You remove the chrome starter cover (two bolts) then the two bolts holding the starter in place. You then pull the starter out and remove the nut holding the cable that goes to the solenoid.
In any case, if you feel better rebuilding yours, then that is the thing to do! Cheers...
  • Sweet Back
05 Jan 2006 17:36
#16194
On a Police bike you have to remove the floorboard, and the shifter. Since the starter didn't want to budge, I hade to remove the clutch cover to tap on it. Not exactly tough, but not 10 minutes. I purchased a brush plate from these guys. Great dealings and should be here tomorrow. Thats what I call service. Let ya know how it goes.
1996 KZ1000P
  • 77KZ
  • 77KZ's Avatar
05 Jan 2006 19:22
#16223
Glad you found what you needed. Just as a reference here is another site that sells brushes and other parts.
www.ricksmotorsportelectrics.com/index.php
"What do you mean we can't change the alphabet to W,X,Y,K,Z!"
Western, OH, Formerly... Western, NY
1978 KZ650B, 1979 KZ650C, 1978 KZ750B, 1982 KZ750 LTD, 2006 ZX-6R, 2009 Ural Gear Up, 1974 Yamaha DT360 (It's Green Anyway!)
  • marches
  • marches's Avatar
08 Jan 2006 01:20
#16652
My 77 KZ650b will sometimes start using the electric, usually have to kick start or bump it. The starter spins mostly. The clymer says that the problem is likely the started clutch, gotta pull off the top of the motor to fix that, but a friend(harley rider) says it is likely the flywheel. Can anyone suggest some way to determine which it is or what it is if not what I have been told? The battery is good, holding a charge and shows 12v.
77 KZ650b
  • DanOz7Five0
  • DanOz7Five0's Avatar
08 Jan 2006 08:27
#16693
Marches, go to the home page and check your U2Us
  • Sweet Back
11 Jan 2006 17:46
#17320
DanOz7Five0
You Win!!!!
Brush plate came and it fixed the issue. Had some other issues but thats another post, literally. Thanks all for your help.
Post edited by: sweet back, at: 2006/01/11 20:47
1996 KZ1000P
