RandallS1 wrote:
Thank you Wireman and Peterosaur for your ideas and help.
No problem.
Never thought about the battery vent. In the past, the right side mufflers have shown streaks of discoloration on the chrome as if something corrosive ran down over them.
There's a clue. It's worth remembering here that chrome is a POROUS, electrolytic metal.
...The corrosion does appear to start on the inside and work it's way through to the outer skin. It always appears in two locations. First at the muffler tips as rusted through holes and then near the center mounting bolt but somewhat towards the rear of the bike.
There's a number of things going on here, and it's no mystery why that appears to be so.
Strangely enough, for an outfit that operates steel mills, Kaw motorcycles has never been known for the quality of theirs. It's worth a thought that those mufflers showed up at the mill on a scrap barge. There's something over 2000 recipes for specialty steels, and I'd bet that the mix they picked was one of the cheaper ones.
Ditto for their plating.
The steel in the pipes is the most reactive metal in the structure, and especially since it is subjected to the repetitive thermal shock and exposure to exhaust gases, my bet is that acid is getting through the chrome/nickle plating, oxygen binds to the steel, then it's off to the rust races - hence the initial discoloration.
Is there any possibility it might be heat corrosion even though the exhaust tubes are not brown or blue?
That's certain to be *part* of the problem - but not the sole cause. If that were the case - that one side was running that much different than the other - there'd be other evidence - either the pipes would dis-color, or the motor'd be running like a *Wireman Special* - so wheezy, whiny and asthmatic that the problem would be obvious...
