It will not come out!!
- kz-mtd
22 Oct 2006 17:44Please Log in or Create an account to join the conversation.
- steell
Re: It will not come out!!
22 Oct 2006 18:01
If you have all the bolts out and still can't get the motor to move, then you don't have all the bolts out.
Take a real hard look all around the motor, there is probably one bolt you missed.
- kz-mtd
22 Oct 2006 18:29
steell wrote:
I made sure every bolt was out and I can jack the motor up/ move it around:blink:If you have all the bolts out and still can't get the motor to move, then you don't have all the bolts out.
- rstnick
22 Oct 2006 18:47
They are a heavy beast to lift out. Have a buddy give you a hand.
Some will lay the bike on it's right side and lift the frame off the engine.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- steell
22 Oct 2006 19:08
You just have to find the right angle and tilt to get the motor to clear, it's almost always easier if you have the cylinder head removed.
It's a real bear to pull a complete motor from the frame.
- 79MKII
- Love Them Kaws!
22 Oct 2006 19:33
Yea, I don't know what you're planning on doing, but if the head and cylinders are removed it's waaay easier. I lifted the bottom end out myself recently (sure, I nearly killed myself, but it was worth it:evil: ) If you are planning on tearing it down anyway, at least pull the head and maybe the cylinders too. BTW, you do know that it will only come out one side of the frame, right? (I guess we shouldn't assume anything) It must be removed from the right side. Just want to make sure we don't over look the obvious issues :whistle:
Post edited by: 79MKII, at: 2006/10/22 22:34
The Kaw List:
- wireman
22 Oct 2006 19:40
pull the exhuast studs out of head ,it really frees up some wiggle room.
- wiredgeorge
22 Oct 2006 19:57
The engines don't get tight in the frame. There is a front upper and lower motor mount. There are rear upper and lower mounts. There are also mounts down below the foot pegs on both sides. I imagine these might be the ones you forgot to remove. Put a jack under the engine and put some up pressure (not much) on the engine while you pull the last mounts as they are much harder to remove if the engine weight is on them.
- 77KZ650
22 Oct 2006 22:23
you are removing part#'s 54 and 47 from the frame right? not just unbolting the motor from them...
Post edited by: 77KZ650, at: 2006/10/23 01:24
07 MDP Rookie of the Year
- wireman
23 Oct 2006 02:43
77KZ650 wrote:
youre not getting drunk and trying to pull it out left side of frame are ya?not that id admit to ever trying to pull a motor out myself after a dozen margaritas or anything like that! :whistle:
- DanAir
23 Oct 2006 02:52
Hey Wireman,
You come up wif da most funniest pictures!!!:woohoo: :woohoo: :laugh:
- wireman
23 Oct 2006 02:57
well ya know ive got way too much time on my hands,the hardest part is saving them for the right moment!
