77 KZ400 balancer
- kawasaki mark
Re: 77 KZ400 balancer
21 Nov 2005 09:38
I'm not sure what wallory metal is; but I'm pretty sure I can't get it here!
they only started balancing tires a few years ago; engineering is limited to fixing things cheap.
also, that website you posted a link to said that welding is most common for weight addition, except for exotic or light cranks.
but maybe that means motorcycles?
regards, Mark
regards, Mark
- ibsen22000
21 Nov 2005 10:07
Mark, check your Private Messages.
You can take off the balancer chain, but you must keep the balancer weights and everything else in place. This is because of the lubrication to the two middle crankshaft bearings.
- kawasaki mark
21 Nov 2005 10:32
thanks for the email address, I'll write to him directly.
I had read that about leaving the balancers in, but I'm planning to just block the balancer shaft oil feed holes. I think noeprene disks clamped under the [empty] balancer bearing blocks. or maybe nylon.
regards, Mark
regards, Mark
