1000 cylinders on a 1100?
- Mikes82KZ1100
15 Oct 2006 13:49
I'm looking for spare cylinders & pistons for my 1100 so I can slowly have them ready when needed.I don't know if the stroke is different between the 1000 and 1100 or not. If the stroke is the same, would 1000 cylinders and pistons work on a 1100 bottom end?
- Duck
- e vica na i sau na ga
Re: 1000 cylinders on a 1100?
15 Oct 2006 14:23
YES, the 1000 'J' 998CC block and pistons fit just fine.
- Mikes82KZ1100
- APE Jay
15 Oct 2006 17:40
However, Regular non-J 1000 block will not fit. In other words if it says 1015 on it, you can not use it.
Jay
Jay
- Mikes82KZ1100
15 Oct 2006 19:07
Thanks Jay. If I remember right, they changed in 81. I think my old 80 KZ1000 was the last year with 1015cc and kick start. Seems to be parts for 1000's quite often compared to 1100's and I probably won't notice much difference with a stock motor.
- 77KZ650
15 Oct 2006 19:15
just curious, why do you want to go smaller?
07 MDP Rookie of the Year
- Mikes82KZ1100
15 Oct 2006 20:08
77KZ650 wrote:
I'm just looking for spare parts for when I wear the top end out in the (hopefuly)near future. I haven't seen ANY 1100 cylinders listed for sale but see the 1000's quite often. Thats the only reason.just curious, why do you want to go smaller?
- 77KZ650
15 Oct 2006 20:49
Mikes82KZ1100 wrote:
oh, you know you want to get the 1170 kit;) :evil: :laugh:77KZ650 wrote:I'm just looking for spare parts for when I wear the top end out in the (hopefuly)near future. I haven't seen ANY 1100 cylinders listed for sale but see the 1000's quite often. Thats the only reason.just curious, why do you want to go smaller?
- Mikes82KZ1100
15 Oct 2006 21:01
Hmmmmm, I looked at Z-1 and don't see any kits listed for the 1100. Lets see, an extra 70cc.....that would give me what? a extra 1/2 HP? Maybe I need seat belts with that kit.:laugh: :side: :silly:
- 77KZ650
15 Oct 2006 21:12
Look on the
Wiseco website
the 1170 kit comes as either 9.5:1 or 10.25:1 compression ratio. and if you want to resleeve your cylinder block, they have a 1262 kit, 10.25:1 comp.
Scott
Scott
- Mikes82KZ1100
15 Oct 2006 21:52
Thanks for the link Scott. I may go that route for re-build #2 if my cylinders are still good enough to be bored.
- 77KZ650
15 Oct 2006 22:09
no problem, to quote another members sig (not sure who right off the top of my head) "friends don't let friends ride stock bikes":evil:
I cant see why your cylinders wouldnt be fine for an over bore. I doubt the bike would even run if the cylinders were worn out bigger than an over bore:woohoo: . the 750 cylinder block I bought to go to the 810 kit had some slight rust in the bores, but after they were punched out 3mm.. good as new!
Scott
Scott
