Recommended cleaning agent
- scooter_Z650
       Topic Author Topic Author
14 Nov 2005 16:09
    Any suggestions on what to use or how to clean oil from the fins of the engine?  I'm curious as to what most use.
- savedrider
- 1975 Z1-B 900
Re: Recommended cleaning agent
14 Nov 2005 16:25
    It's tedious work.  You can try a toothbrush and Simple Green.  A green scotchbrite pad might work well too.
      Get right or get left!  <*{{{><
- ltdrider
14 Nov 2005 16:29
    Savedrider has the right advice.
Trick is to get them clean once, then to clean them routinely. I use simple green and a parts brush. It's a stiff bristle brush that gets between the fins. Then just rinse with water.
Mmmmm...cleeeaaan.
Mmmmm...cleeeaaan.
      '76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- GargantuChet
14 Nov 2005 19:06
    Gunk engine degreaser. Surprisingly effective, no brush required.
Just don't use it on a hot engine. The heat will dissolve the foam, so you have to keep spraying more on. That's too much work!
Try it once, and you won't regret it.
And after you buy it and are amazed by how well it works, post back here. Everyone needs to use this stuff!
Post edited by: GargantuChet, at: 2005/11/14 22:10
- savedrider
- 1975 Z1-B 900
14 Nov 2005 19:29
    GargantuChet wrote:
Hmmm, I've been disappointed with similar products in the past. I'll have to give it another shot. Thanks
And after you buy it and are amazed by how well it works, post back here. Everyone needs to use this stuff!<br><br>Post edited by: GargantuChet, at: 2005/11/14 22:10
- GargantuChet
14 Nov 2005 21:04
    I was really surprised by how well the Gunk foam cut the caked-on stuff. If my experience was somehow unique, at least having someone else try it and report their experiences with it. It worked really well for me, though.
- scooter_Z650
14 Nov 2005 21:57
    Yes, I've tried Gunk and had mixed results.  Will try Simple Green with a stiff brush and compare the results.  Thanks!
- patmann
15 Nov 2005 08:41
    Make sure you spray the Simple Green off any polished parts FAST!!! As I had it s-l-i-g-h-t-l-y discolor some polished parts:(  But Mothers and Semi-chrome took care of it:)
Come to think of it , the engine might have been warm when I did it. So it might have been me not following directions :whistle: :whistle:
Pat
Post edited by: patmann, at: 2005/11/15 14:43
Pat
      1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- scooter_Z650
15 Nov 2005 09:05
    I'll make a note to keep Simple Green off of the polished stuff.  That "was" one of my many next winter projects until a valve guide started leaking.  Thanks!
  Thanks!
   Thanks!
  Thanks!  Please Log in or Create an account to join the conversation.
- DasTeufel
15 Nov 2005 14:12
    Just cleaned my bike with some Gunk degreaser..WOW!! We have some degreaser here at work that I thought was the best you could find..but that Gunk took the gummy oil on my engine right off, just sprayed it on, let it sit for a few minutes, hit it with the pressure washer and no more oil.
      2009 KTM 690 SMC
2008 Kawasaki Ninja 250R
2001 Suzuki GSXR 750
Wildomar, CA
Wildomar, CA
- GargantuChet
15 Nov 2005 14:41
    DasTeufel wrote:
I'm glad it isn't just me. It didn't seem to hurt the metal either -- no etching that I could see. For $3 a can, you can't go wrong!
  That's what I'm talking about! Worked really well for cleaning off the road grit and caked-on petroleum junk.Just cleaned my bike with some Gunk degreaser..WOW!! We have some degreaser here at work that I thought was the best you could find..but that Gunk took the gummy oil on my engine right off, just sprayed it on, let it sit for a few minutes, hit it with the pressure washer and no more oil.
- hwms
15 Nov 2005 16:55
    I am with Chet.
I have used Gunk for years on our equipment and have always had good results. It does not seem to bother the rubber parts and is easy to wash off.
