Oil Change Turns Very Ugly - Mystery Screw on Drain Plug
  • mattb
  • mattb's Avatar Topic Author
21 Sep 2006 20:47
#78644
I am (or was) planning on taking a long ride this weekend, so I thought it wise to change the oil today.
I just pulled the oil plug and it came out like this:
Any ideas what this might be?
So far, my best guess is the screw for a cam chain guide (which would mean pulling the head:angry:).
Post edited by: mattb, at: 2006/09/21 23:52
  • wireman
  • wireman's Avatar
Re: Oil Change Turns Very Ugly - Mystery Screw on Drain Plug
21 Sep 2006 20:52
#78646
can ya post a picture of it?;)
  • mattb
21 Sep 2006 21:02
#78649
Sorry - technical difficulties.
  • mattb
21 Sep 2006 21:04
#78650
  • mattb
21 Sep 2006 21:07
#78651
I'm guessing it is number 11.
www.kawasaki.com/Scripts/ImgServ.exe/con...ilBR=0&ilIF=P&ilRE=8
I replaced that guide when I put the bike together, and I think it had locktite.
Bike is running like a top with no cam chain noise.
  • wireman
  • wireman's Avatar
21 Sep 2006 21:53
#78661
bummer id say pull valve cover 1st and peak down in there,is it making any noise?;)
  • mattb
21 Sep 2006 22:21
#78666
I pulled the valve cover, and everything looks fine from up top (though you can't really see that much). My pop has a fiber optic scope that you can stick down pretty far and look around. I'll check it out later, but since the engine has been running good with no noise, I think I'll go ahead and ride this weekend. If I get stranded . . . that's what friends are for, eh?
  • wireman
  • wireman's Avatar
21 Sep 2006 22:28
#78668
thats right:P
  • wiredgeorge
  • wiredgeorge's Avatar
22 Sep 2006 07:58
#78713
Matt, Couldn't tell from the pic if that was a pan head or head head bolt. Which is it?
  • OKC_Kent
  • OKC_Kent's Avatar
22 Sep 2006 08:21
#78716
If that is number 11, then number 12 is somewhere else now.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • mattb
22 Sep 2006 09:03
#78736
pan head. philips.
As for the location of part number 12 (cam chain guide) - Would losing the screw necessarily mean that that part comes lose? I was just talking to my dad (who did most of the engine work on this bike), and he thought that the guide might have been wedged between the head and the block. Is that just wishful thinking?
  • wiredgeorge
22 Sep 2006 09:10
#78739
That is the ONLY pan head 6mm (about 3/4" long) in the engine that I can think of... the one that holds the front cam chain guide... It has two arms that sandwhich under the cylinder head in little channels. If it were mine, I would pull off the cylinder head and put the pan head bolts back in with some RED LOCTITE. I would not try letting it rattle in there loose. I use RED LOCTITE on all bolts internal to the engine cases and you just figured out the reason. That front guide... when you take it out, it is mostly a rubber type stuff except for the topmost part which is either plastic or plastic coated rubber. Once it starts to wear, it will disintigrate REAL QUICK. You can tell a bad one by looking closely and flexing it. If you see a horizontal crack develop when you flex it, just replace it with a new one. I bet yours is either deteriorated now or cracked so get a new one from z1enteprises.com!
