Help identify engine noise ?
- Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- kawsakiman
- Thank you received: 6
- wiredgeorge
- wireman
- Visitor
- kzmarvo
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- wireman
- Visitor
boy you suck 1 cat into a turbo and they never let ya live it down!:ohmy: :whistle:Make sure there isnt a cat stuck somewheres in your bike.
- Exitpupil
(We did lose a family cat in the 60's when my dad started the car with it laying on the warm engine in the winter, no electric fans back then. Fur was flying out from under the hood but there was no whine.)
- oldkaw79
- floridamba
- Thank you received: 3
Maybe your starter is running on due to a problem with the solenoid or starter button? The clutches would disengage and it the engine would not drive the starter - this is how the starter clutch is designed.
Where are you located? I'm in Jax, FL
- Exitpupil
- floridamba
1. disconnect the battery ground
2. remove gas tank
3. remove 2 bolts over the chromed starter cover, under the carbs on the left side.
4. remove the two bolts holding the starter in place
5. push the starter toward the right side of the engine and lift it up out of the starter bay
At this point you have about 30 minutes into the job and have two things you can do.
1. reconnect the battery and don't ground any of the big cable that goes to the starter... turn the key on and press the starter button and release. See if the starter stops turning. Be careful as this might cause the starter to flop around due to the torque and it could short out the big power cable. Starter must be touching the engine for a ground.
2. with the engine NOT RUNNING, you can stick your finger in the round hole where the starter drive goes. There should be a large gear, fairly thin, and you should be able to turn it one way but not the other. This is the starter reduction gear that engagesw the starter clutches. If you can turn it one way freely and not the other, then the starter clutch is OK.
Hope this helps... IM me if you want to talk over the weekend.
