0.020\" off
- wireman
Re: 0.020
27 Aug 2006 18:55
steell wrote:
im getting to that point in life that everytime i try and learn something new i forget something old,so i better just stick with what i kind of know!
although some of those smaller bikes in the galleries are pretty cool looking!
thats all ive ever really been around is big and really big motors!nfswift, those 0-rings go around the bottom of the cylinder sleeves and seat against the case.
Wireman, I don't know much of anything about the 900 or larger motors, I am just a 750 twin and four cylinder guy
- nfswift
Re: 0.020
27 Aug 2006 18:56
Oh %)*%*#, is it bad to run without them? :blush:
I didn't find any when I took the barrels off???
- wireman
Re: 0.020
27 Aug 2006 18:56
APE Jay wrote:
JAY-1 otherguy-0 :evil:
ouch!Jay_G wrote:This will not happen if you have the correct equipment for doing the job.Well i just dropped the barrels (jugs) off to the machinist and he said he prefers to machine the head. Mainly because going from aluminium to cast steel when machining the tops of the barrels causes the cutter to chatter because of the different hardness of the two materials. he did say something about doing the barrels in certain cases to bring the piston closer to the top of the bore.
Hopefully i will have them back at the end of the week.
Jay
- steell
Re: 0.020
27 Aug 2006 19:29
nfswift wrote:
They fit around the sleeve, flush with the bottom of the block, pretty easy to miss if you don't know they are there.
If they are not there, you might have some oil seepage at the cylinder base gasket, or you might not
Are you sure you did not just overlook them?Oh %)*%*#, is it bad to run without them? :blush:
- Jay_G
Re: 0.020
17 Oct 2006 05:04
Well, progress report, Got the jugs back and the guy did a great job, im going to take the head off to the shop in a few days for some work.
It seems that the general consensus is 0.030 thou is a good amount of meat to take off the head.
Theoreticly i shouldnt have any problems running the bike on 98 octane fuel and have it pinging should i???
i have attached a pic of the pistons on the rods. I have since put the jugs on (ring end gaps and clearances were all spot on) but dont have a photo yet.
Post edited by: Jay_G, at: 2006/10/17 08:05
Post edited by: Jay_G, at: 2006/10/17 08:06
- Jay_G
