Chrome plating or polishing, whats the best?
- JMKZHI
Last edit: 22 Feb 2013 11:34 by JMKZHI.
- Sleepy
Re: Chrome plating or polishing, whats the best?
16 Oct 2006 18:22
chroming adds layers of metal to the surface - and more importantly the various holes used for oil level window, seals, collars, threaded holes etc - so expect covers to be a little tight fitting after chroming, and needing to chase any threads with a tap before you can use them.
Im not a fan of chromed aluminum, the covers on one of my bikes look like real bad with blistering and peeling.
kz650 gs750 cb750
- racer54
16 Oct 2006 19:34
Personally, I like the chrome over polishing. I polished some parts years ago and it seemed all I did was keep polishing to keep the shine. I polished some mag wheels and coated them with urathane clear and they stayed in great shape, but I've been told clear coated engine parts will yellow, which would look like crap. Chrome is easier to keep clean but I was told it also holds heat in, which will make the motor run hotter, but not sure to what degree. I wouldn't think it would be that much to worry about though...otherwise a lot of the bikes on here wouldn't run, huh? If you chrome, spend th emoney and get the good stuff-it's worth it in the long run!!!!!
- wireman
16 Oct 2006 21:03
the older i get the lazier i get:P i like the looks of polished aluminum but i will never again polish carb tops or bowls,valvecover,crankcase vent or aluminum swingarms.they will be plated from now on,too much of a pain to keep polished like racer said!:evil:
