valve lapping compound?
19 Aug 2006 22:13 #71001 by 77KZ650
valve lapping compound? was created by 77KZ650
from all my reading about lapping valves, i can only confirm that it comes in coarse and fine. i cant find any specific details on this, are there more than just the 2 kinds? also what brands make it, and where can i get it? (local shop?)thx
Scott
07 MDP Rookie of the Year
19 Aug 2006 22:40 #71006 by steell
Replied by steell on topic valve lapping compound?
It is available in different grades just like sandpaper. IMHO coarse is only needed when there are pits in the face of the valve or the seat, otherwise I use either a medium grit or fine grit.
19 Aug 2006 22:41 #71007 by nads.com
Replied by nads.com on topic valve lapping compound?
I use a coarser grade and it seems to work fine. Some valves take a while to lap, espescially if they are nitrided. A fine grit may be frustrating there. I guess a smoother surface would not pick up carbon as easily but opinions fly around here so maybe someone else can shed more light.
20 Aug 2006 01:54 #71029 by Mcdroid
Replied by Mcdroid on topic valve lapping compound?
77KZ650 wrote:
also what brands make it, and where can i get it? (local shop?)thx Scott
Hello Scott:
The brand I have available to me (down here) is VersaChem and comes in a blisterpak with two small tubes (coarse and fine). There is more than a single brand. As for availability, the store front that routinely sells it here is O'Reilly's Auto Parts...I don't have any idea who might carry it in Canada:S
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
20 Aug 2006 07:04 #71064 by 77KZ650
Replied by 77KZ650 on topic valve lapping compound?
Thanks for the comments, Ill check out a few local places.
25 Aug 2006 10:49 #72412 by MDawnz1
Replied by MDawnz1 on topic valve lapping compound?
The stuff I use is named "Clover Compound"
Use it like sandpaper , start coarse and finish with fine .(yes I do know it gets finer with use)
I use 2 marks a lot markers RED for the seats and black for the valves to see what I'm doing .
Does anyone else use the fuel line on the valve stem trick instead of those dumb cup tools ?
1974 Z1a, still 903
25 Aug 2006 11:07 #72419 by Mcdroid
Talk to me about this...I get the concept and I do own the 'lapping' tool. The special tool does work but it's kinda a pain to use. :)
Post edited by: Mcdroid, at: 2006/08/25 14:08
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
25 Aug 2006 11:42 #72425 by steell
Just stick the valve in place and slide the fuel line (or any appropiately sized rubber hose) over the end of the valve stem. It does require the head be supported above the work surface, or flipping the head repeatedly.
I just use the suction cup.
25 Aug 2006 11:43 #72426 by MDawnz1
You just hang the edge of the head off the bench cc up .
Mark your valves and seats with markers .
Put on a dab of compound , drop in the valve .
Slip on a piece of fuel line onto the stem .
And do your lapping motion pulling DOWN with the line between your palms .
If you pull to hard the line pulls off the stem (safety)
You can do an 8 valve head in just minutes .
Plus , you can see what you are doing without that tool in the way .B)
1974 Z1a, still 903
25 Aug 2006 11:46 #72427 by MDawnz1
1974 Z1a, still 903
25 Aug 2006 11:46 #72428 by MDawnz1
1974 Z1a, still 903
25 Aug 2006 11:47 #72430 by MDawnz1
1974 Z1a, still 903
