- Thank you received: 3
KZ650 to 750 question
- medic24
- apeman
I understand this is doable, but I have never done it. I know the cam sprockets and chains are different.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- medic24
Post edited by: steell, at: 2006/08/16 19:13
- 77KZ650
- Thank you received: 7
07 MDP Rookie of the Year
- DanOz7Five0
- steell
KZ750 four cylinder was first introduced as a 1980 model, and the 750 twins were made from 76-80, and 82-83, there was no 81 model 750 twin.
It's eBay, so "Buyer Beware"
- reborn650
If you swap to the 750 top end, you will need to swap cam sprockets with your 650. the early 650s use a roller chain, while the 750s use a hyvo. using the 650 "roller" sprockets on the 750 cams is how you make your crank work with the 750 stuff. and yes you will need to enlarge the holes in the case to fit the larger sleeves, its not hard.
Hey medic24.
77kz650 is correct on the swap as I just did this and it is pretty much a bolt on.
If you retain the 650 roller cam chain after swapping 650 sprockets onto the 750 cams, you should also keep the 650 cam chain adjuster that is mounted on the back of the cylinders under the carbs.
You might want to also look at the carb issue. If you are keeping the stock 650 carbs you may have to rejet the 650 carbs to compensate for the extra displacement. Of course, then you will want to bore the 750 to 810, mill, port and polish the 750 head etc....
1977 Kz 650 Custom with 14,000 miles. Wiseco 810, WG Mikuni 28's and lottsa go-fast goodies.
-1998 Jeep TJ Wrangler 4.0...
- medic24
- medic24
If so, any expected "issues"?
- DanOz7Five0
I used the 650s Mikuni VM24 carbs and they were fine for me. I was never out there racing, but the bike moved me around good enough
- JMKZHI
- Thank you received: 48
- sbjones
- Thank you received: 1
