- Thank you received: 59
seemed like a good idea at the time, now i've got to build it.
- Lorcan
- Speed Loony
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- wireman
- Visitor
Post edited by: wireman, at: 2006/08/16 13:04
- wireman
- Visitor
Post edited by: wireman, at: 2006/08/16 13:12
- Duck
- e vica na i sau na ga
Jay???
-Duck
found it at APE site, so no go on sleeves for the 1260 in a stock J block?
KZ900 / 1000 / 1000J 1200 thru 1260cc big block only GPZ1100 1200thru 1260cc stock block
Post edited by: Duck, at: 2006/08/16 14:28
- APE Jay
- Banned
- Thank you received: 58
AFAIK sleeves for the 78mm pistons fit both 998 and 1089 J blocks and both require boring the block.
Jay???
-Duck
KZ900 / 1000 / 1000J 1200 thru 1260cc big block only GPZ1100 1200thru 1260cc stock block<br><br>Post edited by: Duck, at: 2006/08/16 14:28
You can do a 1260 in a stock GPZ block, as per the APE website. Not 100% sure if a 1000J block will take it. We have done a boat load of 1200 1000Js.
KZs will be leakers if you use a stock block.
Jay
- Duck
Jay???
-Duck
Jay
Jay-
I've got both 998 and 1089 blocks on the bench up at the shop and will compare by measuring the next time I'm up there. They looked to be the same but a few mm difference on something that big will easily escape my eye. Especially with one black and one silver. Where might it leak? Around the base?
