kz 750 twin excessive vibration
- steell
I seached the archives but couldn't find that thread, I know the giy went a "lot" higher than 17/38, and am pretty sure it was 18/34 or something like that, and he was looking for a smaller rear sprocket :woohoo:
I figure he must have weighed 100 lbs soaking wet to deal with that kind of gearing
Biquetoast, I bet you posted in that thread also, I remember there was a pretty active discussion going on
- ndali
I will let you guys know how I turnout, thanks for all the help
- trippivot
- Thank you received: 3
triumph 650 vibration in excessive
or a bonneville 750 a rider cannot keep feet on pegs at 60 mph that is vibration! 360 deg. crank design ( both pistons go up and down at the same time)
gotta think there is 2 350cc lumps shaking up and down in there with a 180 degree crank design.(one up one down) this is one way to use dynamic balance to make it twice as smooth as the 2 bikes I mentioned before (half the vib.)
I hate to say you might be chasing a ghost
if its too much sell it and get a inline 4 or a flat 6 those are smooth running engines
- Biquetoast
- King Jeremy The Wicked
That's kinda where I was at *until* he mentioned he gets 33mpg. That's when I started believing that there is something seriously wrong. My twins ALWAYS get over 40mpg, no matter how hard I run them, and usually between 45 and 50mpg.how many bikes have you owned? twins shake .....
I hate to say you might be chasing a ghost...
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
- ibsen22000
- Thank you received: 1
1. Loose engine mounting bolts.
2. Carbs out of synch.
Also check the vacum piston diaphragms fro cracks. If one is good and the other isn't, one cylinder will get more fuel than the other and it might cause vibrations.(I'm not shure about this though, but it is well worth checking them anyways.)
3. Worn out or stretched drive chain and sprockets.
4. Worn out or excessively stretched primary chain.
5. Worn out balancer chain on the crank balancer. If the balancer chain sprocket on the crankshaft wear out, the balancer chain can "jump" a tooth (or several)on the sprocket and the counterweights gets out of timing with the crankshaft and the pistons. And the sprocket can not be replaced, so you will need to replace the crankshaft.
6. Worn crankshaft main bearings.
- ndali
For some reason it was able to idle and run fine at lower rpm, but when it went higher the bad resistor caused the engine to misfire, ie not a good or consistent spark. I am not completely sure of the theory behind it, and why the resistor is in the circuit, either series or parallel, but that was the problem.
I replaced the boots and wires after I ohmed it out and discovered this, and it ran very smooth.
Thanks for the help, the tip about checking if there is vibration on acceleration as well as deceleration help to pinpoint the area of the problem.
- ndali
thanks for all the help, me lesson is to replace the cheapest, easiest parts first when there is a problem.
- Biquetoast
Yay!The issue is solved; it was the spark plug boots.
Boy, I was close, zooming in on the coil, thinking one cyl. No cigar though.
Glad for ya!
kz750twins.com
- loudhvx
- Thank you received: 1616
The KZ twins are remarkably smooth for twins. Everyone I know who used to ride the Honda CB twins always can't believe how smooth the KZ twins are.
If it's bad enough to seem unusual, it probably is something wrong.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- ndali
The bike got 45 mpg running at 5k rpm and 70 mph. I have the original 16/38 configuration. I was hoping to get around 55 mpg on the highway, was wondering how your bike performs and what specs you have on it.
