Random Spec of Learning
  • TexasKZ
  • TexasKZ's Avatar Topic Author
26 Nov 2026 09:15 - 26 Nov 2026 09:30
#929359
Every now and then I run across some random esoterica that tickles my fancy. Here's one.....
In every Z1 there is an annoying little ball bearing in the clutch assembly that the clutch rod presses against. As it turns out, the Z1 is not the first or last model to use that little ball, nor is it restricted to clutch duties. It is part number 600A1200 or 600A1-200, 3/8 (9.525mm) ball bearing,
It was used as early as 1971 in the MT1 Mini Trail and at least as late as 2012 in the Ninja 250. In between it was used in a wide variety of models (CMSNL says 500 models) including the Z1 / KZ900 / KZ1000, KZ400 / 440/ 550/ 650/ 750E, ZG1000 Concours, Ninja ZX11, the ZRX1100 / 1200 and the mighty ZG1200 Voyager.
In most of these models it was used in the oil pressure relief valve, both the remote variety and the style inside the oil filter bolt.
Kawasaki sure got its money's worth out of that little ball.
Happy Thanksgiving!
Last edit: 26 Nov 2026 09:30 by TexasKZ.
The following user(s) said Thank You: MFP-Joe, kimchella
  • asphalt900
  • asphalt900's Avatar
Re: Random Spec of Learning
26 Nov 2026 09:24
#929361
Around as long as the always festive Holiday Cheeseball!
  • the don
  • the don's Avatar
26 Nov 2026 11:07
#929363
yes
how small
but what a huge roll [sorry if thats a pun]
that poxy ball bearing is pivotal for all kz owners
​​​​​​​if you want a functioning clutch
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
26 Nov 2026 12:40
#929365
That ball is also in a bunch of Honda's.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
27 Nov 2026 05:53 - 27 Nov 2026 05:55
#929374
   Almost certainly a common size commodity item.
   Wouldn't be surprised to find them in things as wide ranging as big snow blowers, dishwashers, perhaps those giant industrial ceiling fans seen in tall factories.  Maybe even those commercial toilet flush valves could pull the undies off a seated dinosaur when triggered.
   Having said that, it's the encyclopedic knowledge of all things minutiae and arcane, like the cross referenced motorcycle applications known by only a few of our fellow bike enthusiasts, that are strangely satisfying by routinely humbling us.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 27 Nov 2026 05:55 by slmjim+Z1BEBE.
  • asphalt900
27 Nov 2026 07:30
#929376
Those are as pedestrian as sliced bread, just a round ball. Find loose ones at Ace Hardware for 19cents a piece. Because i don't use tapered bearings in restoration projects, just purchase the 1/4" individual balls in bulk. Absolutely no difference, just sans the "pricey" packet from Any bike manufacture.
  • the don
  • the don's Avatar
27 Nov 2026 10:48
#929379
omg
pull the undies off a seated dinousaur when seated
what a wonderful description
what a wonderful imagination
